Took a little trip.. My thoughts
So drove up to Lake George, NY on Sunday.
I ended up having to stay on cruise control because I was cruising at 80, without even realizing it. I filled up on 93 ( it was 3.66 a gallon) drove 280 miles round trip average speed DIC 68mph average MPG 32.5 mpg I am impressed :smile: |
Originally Posted by stephenm
(Post 301269)
I ended up having to stay on cruise control because I was cruising at 80, without even realizing it. I filled up on 93 ( it was 3.66 a gallon) drove 280 miles round trip average speed DIC 68mph average MPG 32.5 mpg I am impressed :smile: Mine also showed these number coming from Dayton. |
Not me, best I've done so far is 23.67. I've got a little over 3,000 on the clock so far.
Originally Posted by 405HP_Z06
(Post 301277)
(Post 301269)
I ended up having to stay on cruise control because I was cruising at 80, without even realizing it. I filled up on 93 ( it was 3.66 a gallon) drove 280 miles round trip average speed DIC 68mph average MPG 32.5 mpg I am impressed :smile: 55mph =37mpg 60mph=35mpg 65mph=32.5mpg 70mph=29.5mpg 75mph=25mpg 80..well i never drive that fast long enough to know. This is what I believe youll see if you use cruise. I dont use cruise so my number will be 2-3mpg higher across the range. Drag is everything. Speed=fuel consumption. |
(Post 301277)
Originally Posted by dedecv3
(Post 301279)
Yeah i can't seem to get above 24 no matter how hard i try. I've only got 1100 miles. Average speed is 38 MPH. I rarely get on the gas.
You guys are simply having more fun in your SS than me. I have a 37 mph average over the last 400 miles and can't seem to keep it above 35mpg. "Getting-on-the-gas" should be defined by your vacuum gauge going above zero. On the highway i don't let it pass above negative ten (-10) if I can help it. I 1-3-5 shift. Or 2-4/5 shift on a downhill. https://www.chevyhhr.net/forums/fuel-economy-hypermiling-47/absurd-mileage-17070/ |
Those are some good numbers.....I am averaging about 15mi/gallon......not bad for a 1/4 mile track.....lol
I've gotten 26+ MPG on the first two tanks, doing a lot of local driving and then getting on it quite a few times recently.
Originally Posted by Clevelandhhrss
(Post 301286)
??? Not that driving the SS like you stole it is a bad thing, but DO YOU? Reset everything and check you highway cruise MPG's vs the ones I posted above. If that is what you see, the culprit is your foot.
You guys are simply having more fun in your SS than me. I have a 37 mph average over the last 400 miles and can't seem to keep it above 35mpg. "Getting-on-the-gas" should be defined by your vacuum gauge going above zero. On the highway i don't let it pass above negative ten (-10) if I can help it. I 1-3-5 shift. Or 2-4/5 shift on a downhill. https://www.chevyhhr.net/forums/showthread.php?t=17070 |
i've never gotten over 24mpg either ,, but it does get better mpg than any of my other cars so i aint complaining
