Under boost!!!! WTF!!!!
Old Jul 27, 2019 | 05:15 PM
Rudy Jimenez's Avatar
Angry Under boost!!!! WTF!!!!
Every time I get on it boost jumps to 13psi just b4 1-2 shift and then no boost. When I turn it off and back on I have boost again. As long I stay under 5psi the car runs great. I already checked everything there is nothing wrong mechanically with it. I see a few trades about the same thing but don’t see what fixed it or what caused it . I’m Fuster rated it with it already
Old Jul 27, 2019 | 06:11 PM
Pull the codes. If it is resetting after each key cycle, then a trouble code should be present in the OBD system.
Post the code numbers here (no descriptions) and we should be able to point you to the problem.
Old Jul 28, 2019 | 03:42 PM
will1528's Avatar
not a mechanic by any means , but could it be a vacuum leak .. I had one where the airbox pipe goes into the turbo & was not getting much bboost at all -- oh well good luck
Old Jul 28, 2019 | 06:51 PM
I checked that but ill check again thanks for your help.
Old Jul 28, 2019 | 06:52 PM
P0299
Old Jul 28, 2019 | 07:22 PM
Looks like possibly a simple fix
https://www.obd-codes.com/P0299
Old Jul 28, 2019 | 10:15 PM
Check the bypass valve diaphragm and the bypass solenoid.
Also check all vaccum lines and connections for leaks, including the vacuum tank itself.
Old Jul 28, 2019 | 10:21 PM
You said nothing was wrong with the turbo so it couldn't be the bypass valve or the wastegate.
Does it have the GMTU kit, if so check the Tmap for banging into the AC and inspect the wiring that may have been crimped instead if soldered.
Check the CAC for tiny leaks, the special clamps must be properly torqued.
Old Jul 29, 2019 | 12:17 AM
Thanks everyone for all the info we’ll go over it once more tomorrow.
pvine
Oct 25, 2017 06:23 PM
stranger
Sep 21, 2008 05:44 PM
Digital_Rapture
2.4L Performance Tech
17
Aug 10, 2008 07:18 PM
thumperz
Aug 10, 2008 08:01 AM
itschaboykenny
Oct 19, 2007 07:12 AM
