Wastegate rod
Old Oct 21, 2016 | 02:50 PM
Nellie67's Avatar
Wastegate rod
I've been searching all over and can't find the answer. Should the wastegate rod move freely? I'm having occassional boost issues from idle where it won't boost at all and ZZP said to check the wastegate solenoid. Thanks in advance.
Old Oct 21, 2016 | 03:15 PM
DrLoch's Avatar
There are to many to count posts about boost issues and fixes one of which is the waste gate solenoid replacement
Old Oct 21, 2016 | 03:59 PM
I wonder if there is a CEL.
Here are 225 links: https://www.chevyhhr.net/forums/esp_...tegate&type=vb
Old Oct 21, 2016 | 04:39 PM
Nellie67's Avatar
No CEL.. I just wondered if you should be able to move the rod by hand. I thought I read that if you could it was bad. I couldn't move mine at all.
Old Oct 21, 2016 | 05:39 PM
I'm probably reading this wrong, but you won't have boost at idle. The wastegate rod is quite difficult to move by hand. Just because the check engine light is not on, there still may be codes stored.
The wastegate is usually associated with overboost, not underboost.
Old Oct 21, 2016 | 06:46 PM
X2. There should be no boost at idle.
briansh73
Oct 1, 2009 07:59 AM
2ohturbo
2.0L Performance Tech
Jan 3, 2009 12:57 PM
mazoo85
18
Aug 3, 2008 09:04 AM
relicstone
Jul 25, 2008 08:08 PM
