Well got it home tonight 09 ss panel
Old Feb 12, 2018 | 12:10 PM
  #31
DrLoch's Avatar
Originally Posted by Cat Man HHR
Being curious, how so ?
It's called a catalyst heating function. It spins up the the turbo and and adjusts the cam angles to get heat into the cat. Some have disabled it, I tried once but it made the cold idle erratic so I enabled it again. I didn't feel like jumping through the hoops to get it to cold idle better with it disabled.
Old Feb 13, 2018 | 06:07 AM
  #32
Chet043's Avatar
Toque steer
Originally Posted by boost8d
Nice numbers! I know that shop very well, your tune is in amazing hands!
how can I keep this monster in a straight line? I’ve driven lots of front wheel drives. But none with this power and toque. It’s all over the road. I need much help do not like being all over the road. Thing is a rocket a crooked launching rocket but definitely a rocket. I know there is something that I can do but not sure what. Thanks for any kind of help or suggestions
Old Feb 13, 2018 | 06:43 AM
  #33
Replace the stock front engine mount with a solid one (if it hasn't been done )
I got the TurboTech Racing mount several years ago. Vast improvement.
Have you read the owners manual ? The SS allows several options on using the traction control and stability systems.
Old Feb 13, 2018 | 08:13 AM
  #34
Chet043's Avatar
Twice
I Hit the traction control button twice it goes in the launch control stutters it like 41
Old Feb 13, 2018 | 09:18 AM
  #35
Oh yeah. Forgot that you've got a tune. Disregard my post above because your tune may have changed the stock settings and perimeters.
But. The upgraded engine mount would be a good investment if your's still has the stock one.
Old Feb 13, 2018 | 01:41 PM
  #36
Cat Man HHR's Avatar
His problem has nothing to do with this. Correct it and then spend money elsewhere.
Old Feb 13, 2018 | 02:45 PM
  #37
His post #32 about torque steer above. Changing the front mount does help with that. I changed mine. Help reduce torque steer. Also eliminates any of the "wheel hop" if he has that.
Old Feb 13, 2018 | 02:55 PM
  #38
Does the HPFP have the insulator in it ? To suppress the noise?
Injector Pump Noise Reduction Cover 12628069
Might be the source of the noise
Old Feb 13, 2018 | 03:59 PM
  #39
DrLoch's Avatar
Does it have an LSD?
Old Feb 13, 2018 | 04:35 PM
  #40
Chet043's Avatar
Traction control off
Traction control off launchs pretty straight. But I’m still going to do that solid mountl and probably the rear sway bar thinking about some coil overs but I don’t see any specifically for this car
