when did brake fix enter production?
I just bought a 2009 ss last night. I hammered the dealer from 7pm till 11:30 pm! it was made nov. of 2008. when did the electric vacuum pump for the morning brake pedal problem go into production?
I'm assuming that my car doesn't have it, due to the production date, but I had no issuses with the brakes this morning.
is there any way I can look & find the vacuum pump? is it visable? |
I would think the your dealer or Chevymgr might be able to let you know through the VIN
1 Attachment(s)
You can only see it from under the vehicle it is mounted to the block next to the oil pan on the passenger side of the vehicle. You would here it at start up too.
Attachment 4816 |
Originally Posted by andyb
(Post 372667)
is there any way I can look & find the vacuum pump? is it visable? The brake issue materializes over time. Mine started at around the 1700 mile mark. Some started sooner, others later. Steve |
(Post 372662)
Originally Posted by ChevyMgr
(Post 372690)
Attachment 4816 |
