Winter Driving
Old Aug 15, 2008 | 01:26 PM
Arne73's Avatar
Even stock black steelies with cop car center caps would look cool. Definitely would double check the back spacing to avoid any fitment interferences.
Old Aug 15, 2008 | 02:09 PM
jerSSey HHR's Avatar
Originally Posted by esmarkey
Pickd up my SS January 31st in the middle of a Michigan snow storm and have been impressed on how well it did in the snow even since. I am sure a true snow tire like the Blizzak would do better, but overall I was very impressed with the Pilots as I was expecting less from such a wide tire. I also have the limited slip, helps in deep snow keeping power to both wheels but should make it "break loose" easier.... Again, I was impressed on how well it did do. Never got stuck, never spun out, but did have wheel spin after full stop just to get moving.
I sure hope you're right, because I don't have the money to go out and get snow tires!
Old Aug 15, 2008 | 03:23 PM
hyperv6's Avatar
The Wheel Vintiques series 07 and 08 are made just for HHR's and fit with no issues.
Old Aug 15, 2008 | 03:33 PM
Michael20832's Avatar
winter wheels
will hhr LT and LS wheels work on a SS with brembo brakes
Old Sep 13, 2008 | 08:39 AM
liv2ryde's Avatar
Anyone know if the SS with auto comes with the limited slip? Is it an option or standard? I lit them up once or maybe twice trying out the launch control and it seemed like it did kick in....
Old Sep 13, 2008 | 08:58 AM
robotworkshop's Avatar
The limited slip (LSD) option is not standard. It was only available as an option with the manual transmission. If your HHR is an automatic then you don't have limited slip.
Old Sep 13, 2008 | 07:03 PM
hyperv6's Avatar
There times a open diff will spin both tires but not with the same force of a limited slip.
My GP is open on the dif and in lose gravel it will spin both but not on sticky asphalt for long distances.
Old Nov 20, 2008 | 01:04 PM
liv2ryde's Avatar
In response to the original post: I have an SS and have replaced my stock pilot tires with Blizzak winter tires. WOW, huge difference in traction. The stock tires would slip on wet pavement and to try to get up an icy hill for example would take skill and sometimes the patience of other drivers. With the blizzaks I have plenty of traction on ice, slush, wet pavement, etc. when others do not. I wish every vehicle on the winter roads could have dedicated winter tires!
Old Nov 21, 2008 | 05:46 AM
Jeff®'s Avatar
Got a good taste of it this morning.
Stock tires. No real problems except for forgetting how long it takes to stop and hearing all the ABS noises all around my head.
Did notice one irritating thing. I got behind a salt truck on the freeway and when I used the washers they cleared everything but one patch right in my line of sight. It never @#$@%@ fails!
Why can't they make the driver's side wiper work like the pass side I will never ever know.
Old Nov 21, 2008 | 08:50 AM
hyperv6's Avatar
I find the HHR like most FWD's a no brainer in the snow to drive.
Winter tires are good to have but not required most good all season tires will get you through anything with this vehicle.
My wipers work fine but I wish I had an adjustment to control the speed of the rear wiper delay. Man does that window get dirty.
I do miss driving my old pick up and steering more with the gas than the steering wheel. I always loved RWD for the fun factor in snow driving.
I try to take back roads and unplowed roads as no one is around and I can get where I am going vs sitting in line on a interstate doing a slow speed creep. The HHR has not put a wheel wrong yet.
