Yep, another Brembo question
Have an '08 SS with LSD, but it didn't come with the Brembo brake option. Well, I scored a slightly used set of Brembo front calipers for my SS. I know I need the brake lines, and other small parts. But what about the front rotors? Did a lot of search foo, but couldn't come up with the answer. Will the existing stock front rotors work, or are the rotors for the Brembo calipers different/bigger? Any help would be appreciated, thanks.
No, stock rotors will not work.
c2vette did this exact conversion some time back on his 08 SS... Here is one of his original posts on the subject. He bought the rotors thru GM I believe. I recall one of his posts having part numbers, etc..
Good luck, and good score!
I wish I had Brembo's also!
https://www.chevyhhr.net/forums/show...ghlight=Brembo
Yeah I read that thread a couple of times, I didn't see any part numbers for the rotors. Looking at an aftermarket slotted and drilled set, but their isn't much out there for the Brembo option.
https://www.chevyhhr.net/forums/hhr-ss-45/brembos-installed-finally-17542/
$80!!! What a deal. Here in Canada the dealer wanted over $200 for each rotor for a 2006 (non-Brembo of course) two years ago when I needed to replace rotors. Hello NAPA auto parts - $60 ea., and still working just fine.
