Adding a 2nd Aux Hook-up to 07 HHR
Hey all,
I'm a HHR nut, and I have a few threads worth looking at. This one however will discuss how to add a 2nd AUX Jack for you HHR. I want to do this, because I have my sirius hooked up and I would like to have an open port in the front of my radio, and seeing as my Sirius is AWLAYS plugged in, I would have an unsightly cable just looking ugly. I plan on having a full write up for this Mod in about a week or less. I will show you pictures with full detail. I will use stuff you can find at Radio shack very easily. This is so I can hide the wire for Direct Hookup of my Sirius, and make my dash look pretty! Enjoy. Some Pics to start off with, coming soon. |
So just so i get this straight.
You are going to be adding a second AUX jack to somewhere other then the face of the head unit. If that's true. You have my attention. |
yes can't wait for write up. I want to hide my hook up for my xm. It is in the front and I hate looking at the cable every day
Originally Posted by twistrman
(Post 361233)
(Post 361233)
You are going to be adding a second AUX jack to somewhere other then the face of the head unit. If that's true. You have my attention. That is exactly what I am doing, i was thinking routing it to go to the fuse block on the right side of the vehicle, so it's easy to hook up. You will still have the AUX on the front of the head unit. |
Originally Posted by ballplr
(Post 361245)
dj --> Not trying to hide anything. This is a pretty simple idea and like me i think is fine, and I don't need a monster audio system for a car I drive in to and from work and am only in fow an hour or so everyday. Plus i like my hearing, LOL! But I do agree with you about buying a radio with Two AUX, but Not sure if any even have this. Thanks.
TO ALL: This WILL VOID YOUR WARRANTY and I assume no liability in that as well. MOD-ON!!! |
Why don't you just install a Sirius FM Direct adapter and hard wire the power & ground to the inside fuse box. The adapter just plugs in to the antenna cable then do the power & ground and your done. better sound no fading in & out ???
my problem with aftermarket systems, is exactly what they are, aftermarket and they look after market. Yes you can do very custom installs and it looks more like part of the vehicle, but it is still obviously after market.
My point being behind this is security. I had a unit I put in in my last vehicle, and I got so tired of putting the face plate on and off for my short trips (pretty much everything) that I just stopped doing it and would drive in silence. Such a PITA. Yeah I could leave it on and then have a higher risk of it being yanked and then have no system on my longer trips (5+ hours to see my family) I have had my car broken into before and luckily my faceplate wasn't there, and I have had the car next to mine broken into with the stereo jacked, and my car was fine with the faceplate off (the last one was at avery upscale apartment complex). On the car I told myself I would just get the best setup GM offered and use it. But they really need a aux input in the back, that's just smart. Would love one of the new radios with the USB, but that can wait. |
(Post 361284)
My point being behind this is security. I had a unit I put in in my last vehicle, and I got so tired of putting the face plate on and off for my short trips (pretty much everything) that I just stopped doing it and would drive in silence. Such a PITA. Yeah I could leave it on and then have a higher risk of it being yanked and then have no system on my longer trips (5+ hours to see my family) I have had my car broken into before and luckily my faceplate wasn't there, and I have had the car next to mine broken into with the stereo jacked, and my car was fine with the faceplate off (the last one was at avery upscale apartment complex). On the car I told myself I would just get the best setup GM offered and use it. But they really need a aux input in the back, that's just smart. Would love one of the new radios with the USB, but that can wait. Well, To All: I have completed this mod, and it works perfectly. I will have a fulll write up with pictures soon. It's Super Easy!!!!! |
