Air Lift (Drag Bags) HOW TO:
Old Jul 9, 2012 | 09:36 PM
PAT HHR08's Avatar
what is the parts number?
Old Jul 10, 2012 | 12:35 AM
IgottaWoody's Avatar
Same bags used for towing.....
Old Jul 10, 2012 | 12:46 AM
American & Proud's Avatar
Rest In Peace
X2
Theres like 100 or so, what Part Number one did you use?
Good pics and good write up.
Thanks
Old Jul 10, 2012 | 05:55 AM
foolmoon_design's Avatar
Kit number: 60776.
For some reason can't give link through my phone.
Old Jul 10, 2012 | 06:27 AM
RobSSTurbo's Avatar
http://m.summitracing.com/parts/AIR-60776
Here ya go.
Old Jul 10, 2012 | 06:30 AM
Thanks Rob, btw. They look like they tuck into the pedders nicely, and provide that much more with the front dropped another inch or so.
Old Jul 10, 2012 | 09:40 AM
XtremeSS's Avatar
Good stuff foolmoon. Great how to. So are you able to deflate them and not even notice they are still in the spring, or is this not reccomeded?
Old Jul 10, 2012 | 11:32 AM
rroadkilll's Avatar
+Will they act like a sway bar for the rear???
Old Jul 10, 2012 | 11:59 AM
OK, I still haven't done any launching, but yes there is a sway bar effect. I rode about twenty miles with them at 25PSI. The nose stayed down and the rear was stable, but higher off the ground than I like. (I will only run them up at the track). Which answers the second question. Yes, I then let the air out to the 5psi recommendation, that just keeps them inflated enough keep in position.
Old Jul 10, 2012 | 07:09 PM
VinceP's Avatar
This is what I was thinking. I will soon be adding a hitch to my Panel. These will work to help keep the back end up and traction to the front?
