All New HHR Owner's Check This!
I posted about this a while back, but since it's so important, I figured it should probably be a "sticky" in the Tips section:
Underhood Fuses Tip
Every new HHR owner should check this out.
There are also several other helpful tips on our "How-To's" page HERE.
Hope it helps,
Underhood Fuses Tip
Hope it helps,
Originally Posted by jbphill1
I Just Pulled My Fuse Cover Today And Guess What
Every Fuse And Breaker Was Not Seated
I Would Have Never Known To Check This Without Your Headsup
Thanks
Thanks
Passenger Compartment Air Filter is GM part Number 52493319 The book says the passanger air filter should be replaced when Car reaches Change Oil Soon message. However it says this is suppose to occur every 10 months. I'm going to get mine checked out when I take it in for service on Saturday for its 2nd oil change/tire rotation.
mute button blues
i was wondering if i was the only person that does not like the mute button on the steering wheel? i seem to hit it all the time. it's bad when you have the stereo crankin and then silence. what a rush.
