Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
Old Dec 27, 2011 | 12:59 AM
  #121
maybe ? I think ? agreed about the codes needin dumped anyhow..
whopper- Hope you have a Great one as well... Thanks man..
Old Dec 27, 2011 | 04:11 PM
  #122
jaime_g's Avatar
only replaced the intake solenoid
Originally Posted by Wee
Put both solenoids in mine about 2 weeks ago after having the hard shifting and traction control light come on....It never did throw an engine code....So far so good....Got both at the dealer for just under $80.
Brian
I was also going to do both, except I'm super broke. Lol. So I did just the intake one, that did the trick for me.. in case that's useful to anyone here.
Old Dec 27, 2011 | 08:03 PM
  #123
Yeah, I didn't see him post what year his was. So hope he figures it out and grabs those codes.
Old Dec 31, 2011 | 06:44 AM
  #124
cpcook's Avatar
I have a 2007 2.2 1LT with the cel on with a P0016 code and I don't see the sensors under my air filter like it shows in the pics. can anyone help me with the location?? the car seems to run and shift fine but I want to take care of this before the weather gets to cold.
Old Dec 31, 2011 | 09:18 AM
  #125
The reason you can't find them, is that the 2007 2.2 doesn't have them. The answer you seek is in the definition of the code received.
Old Jan 5, 2012 | 08:31 PM
  #126
Sno White's Avatar
2009 2.2 may indeed have "Variable Valve Timing"
Originally Posted by whopper
Nope - the 2.2 does not have variable valve timing like the 2.4L, and therefore does not have the solenoids and other related mechanical bits.
If you are having problems, your first step is to get the error codes stored in the DIC if the Check Engine Light is lit. Without that, you are shooting in the dark.
I'm just now getting into troubleshooting my own P0011 code and my 2009 FSM say the procedures are the same for the 2.4 and my 2.2.
So it seems there has been a change around model year 2009.
Old Jan 15, 2012 | 04:15 PM
  #127
foolmoon_design's Avatar
Has anyone experienced this on the SS 2.0 yet? Is the procedure similar?
I have thrown the circuit malfunction code 3 times since yesterday.
Old Jan 16, 2012 | 03:02 AM
  #128
What was the code? "circuit malfunction code" doesn't help much man.
Old Jan 17, 2012 | 09:02 AM
  #129
Sorry Whopper,
It's the same codes associated with the Camshaft Actuator, I just typed what was in parenthesis. showing that the circuit malfunctioned.'
Car is still under warranty so they are taking care of this today, and I'm having them clean the throttle body as well. for my own piece of mind. I cleaned it once, what a pain in the ass!
I saked them to replace the 2nd actuator as preventive maitnence since they were doing one of them. (I would have paid for it). They told me chevy won't let them replace parts like that. Weird.
Old Jan 17, 2012 | 10:52 AM
  #130
"camshaft actuator"? I gather you mean Camshaft Postition Actuator Solenoid?
Yeah, the dealer won't replace it under warranty unless there is a noted indication of a problem, which makes sense. But one would think they would love the exta $'s from you to replace the non-failed part - but I bet they would want to charge you shop-rate for replacing it, even tho' they already had it torn down for the warranty-replacement.
Hope it works out for you man.
