Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
Old Feb 19, 2013 | 06:38 PM
  #231
MichiganMarty's Avatar
safetyjedi,
You really need to pull the codes before you do *anything*. Then come back here and get help by searching on the code(s) (i.e. DTC P0010) you pulled from your vehicle. Your issue could be a number of things so please do yourself a favor and pull the codes first.
The fix discussed in this lengthy thread may not fix your vehicle if it is not the same issue!
Many auto parts stores (O'Rielly) will pull your codes for free.
This is one of the best forums I've ever run across. That said, consider yourself blessed you found it!
Good luck and happy wrenching!
Old Feb 19, 2013 | 07:17 PM
  #232
All,
Tonight on the way home from work, my car experienced the CEL and T/C lites. First the T/C, and about 3 miles down the road, the CEL. So when I got home, I pulled the codes (P0010, P0011 and C0561), then pulled up the GM Service information web site (lucky me - I work for GM) and then here to see what everyone is doing.
This site is awesome and very informative - for non wrencher's and wrencher's alike!
My 2007 2.4L has 115,000 miles.
The only thing I can see different is the procedure specifies engine oil quality, oil pressure, incorrect viscosity and low oil level can also set these codes. It goes on to recommend changing the oil if it is due.
I use only synthetic oil of the correct viscosity in my car and it is changed at more frequent intervals than recommended, is only about 50% into the next scheduled change, and the oil level is fine. I doubt that the oil is my issue, but for others, I can see where it could be.
A multimeter check on the units prior to changing them, will be performed, but I don't believe the resistance value is the definitive and final answer. They could be bad even if they have the correct value.
And... I am going to change the oil prior to doing anything just to see if it makes a difference. If it does, I am sure it won't be for long!
One last thing, the torque value for the solenoid valves fasteners are 10 Nm !
Just trying to help!
Old Feb 20, 2013 | 06:54 PM
  #233
MichiganMarty. Your last 2 posts have some good comments. You sound like a knowledgable person. Thanks for the input.
Old Feb 21, 2013 | 01:47 PM
  #234
dopplerjeff5000's Avatar
Hello,
I'm new to the forum, and a happy owner of a "Laser Blue" 2009 2.2 L HHR with ~50k miles.
I'm getting the P0011 code with CEL, but haven't had any noticeable issues. This thread has great info on the changeout of the solenoids for a 2.4 L. (And it looks like a job I can perform easily.) Does anyone have advice in terms of difficulties encountered on a 2.2 L?
v/r,
dopplerjeff5000
Old Feb 21, 2013 | 06:38 PM
  #235
hbe1974's Avatar
Do you know if the procedure and part number are the same for a 2007. P0013 code. Replaced exhaust camshaft sensor. Engine light came right back on.
Old Feb 21, 2013 | 06:43 PM
  #236
hbe1974's Avatar
P0013...changed sensor. Engine light right back on...need some help..
Old Feb 21, 2013 | 07:00 PM
  #237
Sno White's Avatar
My GUESS:
The “sensor” you likely changed is not the “solenoid” that may need to be changed. AND what this thread is addressing.
Others have made this mistake. Seems the code text is misleading as to just what is wrong.
Old Feb 21, 2013 | 07:09 PM
  #238
Sno White's Avatar
Oh, so correct, however if the resistance measurements are high or open the solenoid(s) are indeed bad. Yes, the electrical function of the solenoids could be just fine, yet have a mechanical problem that would not show up in any electrical test.
Old Feb 21, 2013 | 07:12 PM
  #239
Sno White's Avatar
Originally Posted by dopplerjeff5000
Hello,
v/r,
dopplerjeff5000
No difficulties here. I have the same vehicle as you do. Some people complain about getting the air cleaner off, but that is it.
Old Feb 22, 2013 | 07:17 AM
  #240
@ Sno White:
Thanks for letting me know. I'm also curious if you remember the 2.4 L and 2.2 having the same part #. There are so many part #'s listed on this thread it's hard to keep track.
