Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
Old Apr 21, 2015 | 10:19 PM
  #531
Originally Posted by topcat1964
On the tutorial / instruction on the Camshaft Position Solenoid Valve Replacement. Besides the grommets on the airbox, it was easier than replacing the headlight bulbs!
LOL - you got that right. so easy even a Moderator can do it!
Old Apr 25, 2015 | 03:36 PM
  #532
papa_jo's Avatar
I just replace both solenoid's and air filter and have more problems now.
along with engine light still being on. I also have service esc off light on
Old Apr 25, 2015 | 03:41 PM
  #533
See my answer to your other thread.
Old Apr 25, 2015 | 07:33 PM
  #534
Sorry to hear you ran into problems, however two posts with the same issue in it makes it rather difficult to follow. And of course without any code being read and posted, there isn't anything constructive to add from this end. But I assume you disconnected the neg post of the battery during the install of the solenoids?
Old May 2, 2015 | 08:48 PM
  #535
Billy43's Avatar
p0010 error on 2012 chevrolet Captiva
Hi i have read this great thread and i hope u dont mind going over my situation. I have a 2012 4 cyl chevrolet captiva. Check light came on and was told i had error P0010 . The mecanic requested I buy the sensor which i did. And guess what ? light came back on and got the same error. He checked for reference voltage and ground which he states is all good. Now it has a rough idle and it jumps when pulling out.
Now here are my questions...
Could i be having the same issues as this thread?
If so how do i know which of the two are bad?
If i wanted to test them how do i go about doing this.
I hope someone can help me out ....
Thanks
Old May 2, 2015 | 09:05 PM
  #536
Thanks
SOLENOID not SENSOR! Read from post #1.
Old May 2, 2015 | 11:06 PM
  #537
Since you didn't mention what engine you have, and because I am not a mind-reader, I have no comment.
Old May 2, 2015 | 11:17 PM
  #538
Billy43's Avatar
Thanks for pointing that out thanks for pointing that put mind reader or not .
Old May 2, 2015 | 11:23 PM
  #539
Billy43's Avatar
Thanks for the response and i did read the thread and will read again to see if i missed, how to or if possible to test if a solenoid is good or bad. AGAIN thanks for your response.
Old May 3, 2015 | 07:56 AM
  #540
The point is: you stated that you had the SENSOR replaced. The SOLENOID is the problem when you get P0010. This common confusion is addressed within this thread.
It is always a good idea to tell us what engine/age/mileage you have, it does make a difference. For instance; this entire thread does not apply to a 2.2L engine in a 2007 HHR LS.
I have absolutely NO idea if it applies to any engine in a 2012 Captiva!
