Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
Old Jul 7, 2011 | 08:49 AM
  #51
andoll83's Avatar
really? we're not even going to answer my question?
Old Jul 7, 2011 | 08:59 AM
  #52
I thought ChevyMgr just did......
Old Jul 7, 2011 | 09:27 AM
  #53
ChevyMgr's Avatar
Clean engine oil.
Old Jul 7, 2011 | 09:48 AM
  #54
If you reread the post, it clearly said "oil", not grease. So, as ChevyMgr said just use a bit of oil, even if you dab it on off of the dipstick.
Old Jul 7, 2011 | 10:49 AM
  #55
stephenm's Avatar
Originally Posted by ChevyMgr
ky.
Thats only what the dealer uses when they fix it.
Old Jul 7, 2011 | 12:57 PM
  #56
andoll83's Avatar
I replaced both solenoids, but the T/C light is still on.... what could I have done wrong?
A guy at AutoZone told me to put a little white silicon grease on the O-Ring only... was that bad advice?
Andy
Old Jul 7, 2011 | 11:19 PM
  #57
Tikker's Avatar
Did you clear the codes by disconnecting the battery cable as suggested?
Or do you have a code reader to do that?
Old Jul 8, 2011 | 01:51 AM
  #58
Andy
A LITTLE white silicon grease will be ok - oil would have been preferred, as the solenoids are in an oil environment. So don't worry about it.
If T/C light is still on, as Tikker noted - disconnect the battery for a few seconds (did you skip that as the very first step in the process?) - that should reset the system and clear the lit light. If it does not clear it, you have an additional problem somewhere.
Question: once you buttoned it back up, did the hard shifting clear ok?
Keep us updated eh? (Canadianism thrown in for good luck :) )
Old Jul 8, 2011 | 09:48 AM
  #59
andoll83's Avatar
I did disconnect the battery before changing the solenoids....
The T/C light was off by the time I started the car a few hours later, but it came back on, and the hard shifting began again. I had the MAP sensor replaced last year, and just did both camshaft solenoids. What else could this be?
Andy
  #60
andoll83's Avatar
I noticed, while everything was apart, that my air filter is completely black.... will pick up a new one today... not sure if that's at all related though
