Originally Posted by psharer
(Post 651185)
If you have all the tools this takes about 45 minutes to do on each side. I originally thought it was road noise from the tires but did some reading and found out the wheel bearings are known to go early. I also found out Chevy has a 100k warranty on them so if you start hearing humming noise resembling road noise have them replaced.
Originally Posted by Sickdreme
(Post 654093)
Had the pass side done under warrant on my 07, now @54k it seems the driver side has the 4x4 humm. Any info on 100k warranty would be appreciated!
https://www.chevyhhr.net/forums/problems-service-repairs-42/07-09-10-11-powertrain-parts-coverage-list-22231/ |
anyone know what size the axle bolt is? just ordered the hubs off e-bay... do the bearings come packed with grease already?
Originally Posted by MikeloftyHHR
(Post 657687)
Yves |
(Post 657687)
No bearings to pack, sealed units. Pretty easy to swap out also. EDIT: It's a 30mm axle nut. |
ok, here it is again... with pics!
starting place- took off the calipers (14mm) and rotors to get to the real problem...dont forget to unplug the ABS sensor
https://www.chevyhhr.net/gallery/fil...0/hubstart.JPG here is the trouble I first ran into... the axle nut (30mm) is on there good... 155ft/lbs How do I get it off with the wheel and brakes already off? I looked all over the shop and found some angle iron I had laying around and bolted it on to the lugs (it didnt matter because the new hubs had new lugs... https://www.chevyhhr.net/gallery/fil.../hubremove.JPG then its 3 15mm bolts to get the whole thing off... https://www.chevyhhr.net/gallery/fil...5/0/huboff.JPG Keep an eye on how the brake shield is oriented ( took me a second try after it was wrong). Reinstall- I used blue lock-tite in everything... 85lbs on calipers and hub bolts, 155 on axle nut Viola! https://www.chevyhhr.net/gallery/fil.../0/hubdone.JPG |
I can't understand why there is so much 'write up' on this. These have got to be the easiest hubs I've ever changed on a vehicle......
You forgot the part of the procedure that says to "place a punch or similar tool in the brake disk vents (before you remove the caliper bracket) and brace it against the caliper bracket". Then remove the axle bolt, reverse the same way.
And, yes real easy and you should consider replacing the axle at the same time. Only $60 a side and no real extra labor. And maybe the control arms ......? |
Originally Posted by donbrew
(Post 659313)
(Post 659302)
I can't understand why there is so much 'write up' on this. These have got to be the easiest hubs I've ever changed on a vehicle...... Yves |
