How To Install A New Horn
Old Jul 30, 2010 | 12:40 AM
Originally Posted by an08HHR
Auto accessories are 12v so the thing to look at is the AMPERAGE that the item draws. The horn fuse is #60 in the engine compartment fuse block and you will have to see what that fuse is rated at.
That fuse is a 10 amp, But is the horn the only thing on that circuit ?
Old Jul 30, 2010 | 06:20 AM
an08HHR's Avatar
From the wiring chart I have, the horn is the only thing on the circuit.
Old Jul 30, 2010 | 10:28 AM
Thank You, that is exactly what I was looking for..
Old Aug 19, 2011 | 08:51 PM
Carl Fisher's Avatar
Found your info on the horn installation Great ! Mine went quick and sounds great.
Old Aug 19, 2011 | 10:26 PM
WElcome Carl, what type of horn(s) did you install ??
Old Sep 11, 2011 | 12:41 PM
Good morning. Been gone for a spell I installed the Wold Bad Boy. It fit in the orginal space just fine. works good, sounds great!
Old Mar 24, 2013 | 09:24 PM
NCRand's Avatar
I installed my Auooga horn a few months ago, but it sounded like a strangled goose. I thought that maybe I reversed the wires so I took it all apart and switched the wires again- same goose. Dang... I'll probably go with a Big Boy horn later. BTW, I installed my horn using a hole on the bracket that the wheel well attaches to, it wouldn't fit forward due to the fog lights.
Old Mar 24, 2013 | 09:27 PM
NCRand's Avatar
Whoops
Bad Boy. I meant Bad Boy.
Old Mar 25, 2013 | 12:58 AM
You may wanna test that horn on a separate battery, just to rule out a bad horn or not..
How was your ground ?
I'm not into the aoooga horns, but installed triple caddy horns years ago & they work fine.
Old Mar 25, 2013 | 01:34 PM
Smash's Avatar
The way folks are in this city, I'll be going for the same ridonkulously loud Stebel Nautilus (ear blaster) that I have on the bike... it makes texting drivers soil their pants. By adding a relay and feed for that horn seperately, I can run both the Ear Blaster and the stocker at one time... in excess of 130dB SPL. That'll get yer attention.
