Install Rear Seat in Panel
Old May 27, 2014 | 05:23 PM
Remember that in many states you cannot get a safety inspection without seat belts. Which means you may not be able to sell it (legally).
Old Jul 25, 2014 | 08:00 PM
Britjoe's Avatar
Awesome write up and installed my rear seats today, is there a fill panel behind the rear seats?
Old Jul 27, 2014 | 11:45 AM
VinceP's Avatar
There is a small double compartment storage container that goes there.
Old Jul 27, 2014 | 01:16 PM
Britjoe's Avatar
Right thanks I gotta go back to the breakers and pick it up
Old Nov 23, 2014 | 11:12 AM
Lamestdudeout's Avatar
Very helpful, is the steel frame at all structural? I removed to get the most space I could now I'm wondering if I have to replace the bolts?
Old Nov 23, 2014 | 11:28 AM
The steel frame is only there to provide structural support for the cargo bins.
It's not an integral part of your HHR's unibody, so you can leave the bolts out, or run them back into their holes to keep from losing them.
Old Nov 23, 2014 | 12:17 PM
Thanks for the fast reply much appreciated , here's some of my tools stuffed in that extra space helps
Old Apr 19, 2015 | 03:42 PM
jjriskas's Avatar
HHR Back Seat
Thanks for the DIY instructions for the back seat modification.
Just purchased a 2011 Panel (All White) and planning to do so customizing.
Any suggestions on a supplier of after market front grilles and exterior sun visors?
My HHR has plastic inserts where fog lights should go.
Does GM have a OEM aftermarket fog light kit?
Thanks,
JJ Riskas
Old Apr 19, 2015 | 04:30 PM
Yes, nice directions, I used them in 2012 when I installed rear seats in my '08 panel which I never regretted.
The nice thing is that you can put the seats down and have the same amount of room to haul stuff (but you lose the lock boxes).
Boydie
Thanks,
JJ Riskas
Old May 2, 2015 | 01:58 PM
lordairgtar's Avatar
Will I need extra bolts/fasteners for mounting the seat? I got the seat but realized that the yard did not give me the fasteners to mount. What size are the bolts on the front of the storage bin. I already have the proper Torx driver. I'm assuming bolts are metric?
