LED MOD - Radio, HVAC, I/P - Step-By-Step Tutorial 2006-2008
Ever want to change your Factory Lights on the Instrument Panel, Radio, & others. Well now you can. I have done exactly that and I will show you step-by-step on how to do it. If you have any questions please feel free to ask them here. I want to educate everybody on this. Hope you like the Complete Tutorial.
ENJOY! |
Item List & Soldering Instructions/Tips
Item List:
1.) Solering Iron 2.) Liquid Flux 3.) 60/40 Rosin Core Solder 4.) Small Set of Tweezers 5.) 7mm Socket, with Extension 6.) Phillips Head Screwdriver 7.) Small Flat Head Screwdriver 8.) PLCC-2 LED's - For everything except Radio, Rear Wiper Button) 9.) 1.4mm SMD LED's - For Only Radio, & Rear Wiper Button 10.) 5mm LED - For Overhead LED ONLY 11.) Desoldering Braid 12.) Desoldering Pump 13.) A whole lot of patience and a steady hand. For the Radio Only & Rear Wiper Button ONLY (0805 - 1.4mm SMD LED): http://mouser.com/Search/Refine.aspx...PartNumber%7c0 For HVAC, I/P Cluster, 4-Way Flasher Switch, Lock Buttons, & Mirror Switch ONLY (PLCC-2 - LED): http://www.oznium.com/plcc-2 For Overhead LED ONLY: 5mm LED http://www.oznium.com/led I Bought all lights from www.mouser.com and www.oznium.com, which are great sites. Mouser, has the best selection, but may take a while to find the lights you need. Soldering Instructions/Tips: When soldering, you have to remember that patience is key and you must not apply too much heat. If your soldering has a temperature control, set to 800 Degrees, no more and no less. This is the optimal temperature for soldering. When working with the Radio LED's which are really small, I applied a bead of solder to the Negative Solder pad first and then heated up and with tweezers moved the LED into the molten solder, while trying to keep the LED flush with the board. Then I applied Liquid Flux to the Positive solder joint and applied a small bead of solder to my soldering iron and then sldered the Positive side of the LED. Once completed I Heated each side and pressed down, Gently on the LED until completely flush. Your patience will be rewarded, I promise. Practice the samel techniques on all the other lights. In The Radio, There are two LED's which are hard to get to. You need to desolder the Knobs off the board for the Volume and Tune Knobs. Not too hard to so, just use alot of Liquid Flux, Desoldering Pump, and Braid. Once you get them both off, you can get down to the basics of getting all of the lights replaced. Pics soon to follow. |
Removal Instructions:
Radio & HVAC Controls: 1.) Remove Power Window Switch/Bezel & Chrome Trim. Move to the side. 2.) Remove HVAC Controls by taking out four 7mm Hex Screws from the unit (Figure 1). There are three connectors on the back to disconnect. Put this aside for later. 3.) Remove Radio by taking out four 7mm Hex Screws from the unit (Figure 2). There are two connectors on the back to disconnect & the antenna wire to disconnect. Put this aside for later. Steering Wheel Buttons: 1.) Disconnect Airbag Fuse in Passenger side fuse block. It’s the Red 10A. Take a small Allen Key and press in and towards you on both sides of the airbag. There are small holes on the backside of the steering wheel. You may want to open your hood and remove the Horn Relay so you don’t piss off your neighbors. Airbag will pull straight towards you once both springs have been disengaged. Pull the yellow wires gently away from horn switch and put airbag on top of steering wheel (Figure3). 2.) Remove both screws which hold on the left and right hand side controls. Disconnect both switches and remove them (Figure4). Set these aside for later. I/P Cluster: 1.) Remove Left Pillar Mount. Remove Cover, Screw, and Tweeter harness. Set aside.(Figure5-7) 2.) Remove the 7mm Hex Screw. You will be lifting the top portion of the dash board for easier removal of the Cluster. You’ll thank me later by taking a few more minutes. This is a lot easier. (Figure8) 3.) Remove Center two 7mm hex screws on the left and right hand side of the air ducts. Remove Center Storage Bin, by remove two Phillips head screws while open. Lift out and loosen other screw at the back by the defroster duct. Set Aside. (Figure9) 4.) Remove Upper Cluster Bezel by removing two screws. Set aside. (Figure11) 5.) Remove Upper Column Bezel, which snaps off as you pull up. This will give you better access to the next step (Figure12) 6.) Remove two 7mm hex screws which hold the I/P Cluster in place. Try not to drop them, because it’s a pain to find them. Pull from top of cluster down towards the floor to release. To remove the harness use a flat head screwdriver and press in front of the grey art and push the grey part to the left and forward to complete release.(Figure13) 7.) Remove topmost plastic cover by pushing in the lips from the top to the side and then the bottom. (Figure14) 8.) Turn upside down and remove the six Torx screws which hold on the board. Separate the parts, (Figure 15) 9.) Remove all four needles. The easiest way I found is to use a fork, as another member had indicates on a separate thread on this board. Great tip. Use picture for reference. Gently pry up to release needle. Set Board aside. (Figure16) 10.) Picture of LED. For your reference all LEDs on this board are labeled by number and have “A” & “C” printed on the board. A = Positive & C = Negative. (Figure17) Rear Wiper Button: 1.) Remove the four Phillips head screws and remove top cover. (Figure18) 2.) Remove Board from bezel. Set aside. (Figure19) |
Figures #1-#5
5 Attachment(s)
Figures #1-#5:
Figure #1: Attachment 34066 Figure #2: Attachment 34067 Figure #3: Attachment 34068 Figure #4: Attachment 34069 Figure #5: Attachment 34070 |
Figures #6-#9
4 Attachment(s)
Figures #6-#9:
Figure #6: Attachment 34062 Figure #7: Attachment 34063 Figure #8: Attachment 34064 Figure #9: Attachment 34065 |
Figures #11-#15
5 Attachment(s)
Figures #11-#15:
Figure #11: Attachment 34057 Figure #12: Attachment 34058 Figure #13: Attachment 34059 Figure #14: Attachment 34060 Figure #15: Attachment 34061 |
Figures #16-#19
4 Attachment(s)
Figures #16-#19:
Figure #16: Attachment 34053 Figure #17: Attachment 34054 Figure #18: Attachment 34055 Figure #19: Attachment 34056 |
LED Locations
LED Locations:
I/P Cluster: (A=Pos, C=Neg) D801 Water Temp Needle Color D802 Speedometer Needle Color D803 Tachometer Needle Color D804 Fuel Needle Color D806 Water Temp Gauge Color D807 Speedometer Gauge Color D808 Speedometer Gauge Color D809 Speedometer Gauge Color D810 Tachometer Gauge Color D811 Tachometer Gauge Color D812 Tachometer Gauge Color D813 Fuel Gauge Color D815 kM/h Light D816 Mph Light D610 High Beam Indicator Light D601 High Beam Indicator Light D506 Left Blinker Indicator Light D505 Right Blinker Indicator Light I/P Cluster - Bottom Row: D506 Security Warning Light D507 Battery Warning Light D509 Oil Warning Light D508 Water Temp Warning Light D503 Parking Brake Warning Light D605 Check Engine Warning Light D602 Fog Lamp Indicator Light D607 None D608 None D604 Up-Shift Warning Light - (If Manual Transmission) D501 Air Bag Warning Light D504 Seatbelt Warning Light D502 ABS System Warning Light D510 Tire Pressure Light - (If Equipped) D512 None D511 Traction Control Indicator Light - (If Equipped) HVAC Controls: LD1 A/C On Light LD11 Recirc Air On Light LD13 Heated Seat High/Low Setting On Light - Passenger Side LD14 Heated Seat High/Low Setting On Light - Passenger Side LD15 Heated Seat High/Low Setting On Light - Drivers Side LD16 Heated Seat High/Low Setting On Light - Drivers Side LD17 Fresh Air On Light LD18 Hot Temperatue Light LD19 Hot Temperature Light LD20 Cold Temperatue Light LD21 Cold Temperature Light LD22 Temperature Knob Light LD23 Temperature Knob Light LD24 Temperature Knob Light LD25 Fresh Air Light LD26 Heated Seat Light - Drivers Side LD27 Recirc Air Light LD28 Heated Seat Light - Passenger Side LD29 Fan Speed Knob Light LD30 Fan Speed Knob Light LD31 Fan Speed Knob Light LD32 Mode Selection Knob Light LD35 Mode Selection Knob Light LD36 Mode Selection Knob Light Rear Washer Button: LED1 Rear Wiper Left Button LED2 Rear Wiper Right Button LED3 Rear Wiper Center Button Steering Wheel Controls: No Markings - Lights Are Self-Explanatory |
Radio Pictures
7 Attachment(s)
I/P Cluster Pictures:
4 Attachment(s)
