Remove Front Bumper and Swap Headlights
Old Oct 27, 2010 | 05:14 PM
Gas Man's Avatar
I used 1Panel2NV's "How to paint your headlights" as a great guideline. I will expand on that.
I didn't like the stock look
So I put the 3M tinted protective film on the headlights. However, that not only cuts down on my light output, it wasn't the final direction I wanted to go.
Pop your hood and remove the two 7mm bolts on each side of the radiator.
Remove the 7mm bolt from each wheel well
Now remove the 4 push pin clips on each side (2 under & 2 in each wheel well) as shown here by 1Panel2NV's pic
CAREFULLY pull the bumper from the wedge clips on both sides of the headlight. One above each wheel and one right next/above the 2 bolts you removed by the radiator. This requires small tools to help, maybe some tape to protect the paint.
Here's what you are looking at
Passenger Side
above wheel
next to radiator (in front)
Drivers side
above wheel
Old Oct 27, 2010 | 05:17 PM
Gas Man's Avatar
Then you have a bumperless HHR
Said bumper off car
I can now see my HID ballasts and my Wolo Horn
Remove the two 10mm bolts holding your headlights in
Firmly grasp the headlight and pull downwards to release the clips in these slats. Once released unplug your turn signal and headlight bulbs.
You have your two headlights for swapping
You must remove the bracket from your stock light and reuse on your new light. It simply unhooks.
Hook up the headlight and turn signal bulbs, slide the new light into place and snap in. Then replace the two 10mm bolts holding the light in place.
Gas Man's Avatar
Repeat swap on other side
Reinstall your your front bumper. That part is really easy. Then enjoy your headlight swap or upgrade or whatever else you did.
Nice shot of my non-amber covered LED towers
Like McD's I'm Luvin It!
Old Oct 27, 2010 | 05:56 PM
SOMBERSHARK0714's Avatar
Very nice how-to & thanks !!
Old Oct 27, 2010 | 06:43 PM
Great write up, thanks for the photos........ Wonder if the 2LT is much different?
Old Oct 27, 2010 | 06:57 PM
Mrs. DLVRNIT's Avatar
Hey Gas Man,
Nice write up and pictures ! What we like even more is the lights you chose to install ! We actually think they look nicer than our fall editions !
Keep Up the Nice Work ,
Old Oct 27, 2010 | 07:30 PM
Gas Man's Avatar
Thanks & Thanks!
I don't think it is. Compare my thread to the paint headlight thread. The only difference I saw was the size of the bolts on the side of the radiator.
Originally Posted by Mrs. DLVRNIT
Hey Gas Man,
Thanks! And if you didn't already know I'm a picture abuser. I take so many that it can bother some folks, but the pics really make the difference.
As far as the DEPO lights, I like em so far. They are exactly what I wanted. Further, with the sale of my stocks, I can help others get here as well.
Old Oct 27, 2010 | 08:22 PM
mongo's Avatar
Cool, I'm doing this with the spare set i got at home.........
Guess that would make them 'Home Depo' lights, nyuk nyuk nyuk....
Old Oct 27, 2010 | 10:42 PM
Gas Man's Avatar
There ya go. Home DEPO lights!
LUV IT! Take lots of pics.
Old Oct 28, 2010 | 01:33 AM
Very Sharp & agree, they look cooler than the Fall Editions..
