Replacing Lower Control Arms
I just replaced the LCA's on my 08 S due to blown bushings. Wasn't aware they were the solid aluminum ones until I pulled them. The ones that went in were the stamped steel LCA's. All I know is that with the stamped steel LCA's, the front end feels loose, too much flex, and it's noisier than ever now.
Going to replace them with the solid alloy ones, and check the sway bar bushings once I get back from vacation.
The SS LCA's have the FE5 suspension which has a larger ball joint. If you used the stamped steel arms for the FE1, FE3 suspension with the smaller ball joint, then the ball joint is not going to fit snuggly into the knuckle. It would have never tightened down upon installation.
I would advise you don't even drive it until you get the correct parts.
"Front end feels loose and is noisy" should have told you that something was wrong with those new LCA's.
Doing a re and re on the passengers LCA today, as the lower ball joint is dripping a brown water and grease mixture from the seal cover. The drivers side looks good still. time to get the hands dirty again.
Just did this using these instructions and everything went pretty smooth. Most tedious part was getting the rear bushing to line up with the holes but with a little wiggling it went in. Likes to spin loosely for a bit and that tapered end helps it find its way into the welded nut on top. I did have an impact wrench on hand which made removal of that rear Bolt a price of cake. Tightening it was fun too. Overall not too hard of a job. With access to a lift in a shop this seems like a 30minute job easy. Took me just under an hour per side from wheel off to wheel on and I had never done a job like this before. Easy!
Good job! Now if you had a front end alignment recently, you should get another one, those rear bushings can throw the caster and camber way off!
Some front end shops don't really look very hard for worn bushings, maybe the ball joints!
I haven't had an alignment since I purchased the car lol should I just get one for piece of mind?
As Oldblue says - if you had a front end alignment recently - and since you haven't............... nope.
Man, you gotta get a control on that over-thinking thing,
Glad you got them replaced - it's a bit of a messy job, but not that difficult. Chalk that job up to expanding your expertise. Good job man.
