Stock Radio Removal Guide
Old Aug 29, 2006 | 01:31 PM
  #41
elfalfa's Avatar
hey guys Metra has the harness out now....Without pioneer sysetm GMOS-Lan-03 with pioneer it is GMOS-LAN-04 Production is limited as they can only hand make 25 each per day...But I have one and it works perfectly
Old Jul 22, 2007 | 06:40 PM
  #42
alien_sporez's Avatar
Since the SoCal website is no longer up, can someone re-host?
Old Aug 8, 2007 | 05:32 PM
  #43
Skatetheglobe's Avatar
Has anybody had any problems with the harness? The harness I got was totally screwed up. None of the speaker wires were correct so I ended up having to splice into the factory wires.i should have just saved my money instead of buying that crappy harness.
Old Aug 8, 2007 | 05:40 PM
  #44
Which harness?
Old Aug 9, 2007 | 07:14 AM
  #45
I don't even know now. I bought it along with the install kit and ant. adapter in a package. Whatever it was it was a piece.
Old Nov 6, 2007 | 05:21 PM
  #46
clancy's Avatar
Radio Removal
Please!!!!!!!!!!! I would like to remove radio to to tap into power source for XM Thanks
Old Dec 19, 2007 | 05:11 PM
  #47
doeppel's Avatar
Can anyone tell me which power wires I should tap into to add my XM Roady. I am doing a permanet install and have the Delphi kit coming. I want it to stay powered on like the radio does until the drivers door is opened.
I dont have a wiring diagram so if someone can tell me which ones to tap that would be awesome. I'm going to hopefully get it installed this weekend.
thanks,
Dave
Old Dec 20, 2007 | 11:51 AM
  #48
an08HHR's Avatar
thanks,
Dave
There was a thread someplace about that but can't locate it.
Found it: https://www.chevyhhr.net/forums/show...d+power+source
Old Dec 26, 2007 | 11:02 AM
  #49
twelve volt pro's Avatar
Quick question, I want to install an aftermarket stereo in my 06 with steering wheel controls. Do I need a seperate module to retain the steering wheel controls? My wife has an 03 Grand Prix, and a new module is needed to retain hers. TIA
Old Feb 17, 2008 | 02:07 AM
  #50
ricerocket's Avatar
Lcd Hu
I installed my LCD DVD/MP3/CD aftermarket headunit! I'll take pictures and show you guys as soon as I can.
I am done, but I forgot to wire the break wire. I didn't realize that I had to put the break wire with the ground in order to watch dvd while driving (not that I am going to but it's a cool effect for the passengers)...but you guys think you can use the toggle switch for where the fog lights are supposed to go as a break wire toggle switch instead? just an idea, has anyone out there used that spot for anything other than the foglight (my HHR doesn't have foglights)...anyone have any ideas...
