Original Rear Springs .. FE3 SOLD
Old Feb 5, 2018 | 11:35 PM
Silverfox's Avatar
I have for Sale ... 2 HHR 2LT FE3 Sport Suspension Original Rear Springs that are in Perfect Condition.
They came off of my 2011 2LT that only has 27,800 miles on it.
They have no Corrosion.
The springs both measured identical body height from side to side.
This sale also includes the 2 Original GM Upper Jouncer Bumpers and the Lower Spring Plates.
I will also include 2 Brand New GM OE Isolators for the Upper Jouncer Bumpers.
This makes this offering a Perfect and Complete Ready to Install Package.
Price for everything above .... $20 plus shipping.
My zip code is 98382
Private message me your zip code and I will get you a estimated ship rate.
Silverfox
Item Sold 3/2/18
Attached Thumbnails Original Rear Springs .. FE3 SOLD-001.jpg   Original Rear Springs .. FE3 SOLD-002.jpg
Old Feb 6, 2018 | 08:18 AM
aradmahogany's Avatar
Pretty sure the ls/lt rear springs are the same regardless of suspension, and the struts are what changed with the FE3 package, right?
Old Feb 6, 2018 | 08:48 AM
Right, the shocks and bushings are firmer in the FE3 Suspension, the springs are the same as the FE1 Suspension.
No if these are to be used to replace a broken spring or springs on the back end of your HHR the are direct fit. Perfect to refresh that sagging rear end on a decade old set of springs.
https://www.chevyhhr.net/forums/brak...experts-27403/
Old Feb 6, 2018 | 09:42 AM
Silverfox's Avatar
I think the springs still have the original tag on them and as I recall it was not the same part number shown on the GM site for replacement.
I will try get it and post as soon as I can. Everything was Totally Stock when I purchased the car. Glove box RPO shows FE3.
Also as I recall the GM parts diagram shows the same part number for the LS/1LT/2LT for replacement.
P.S. the upper Jouncer Bumper Isolator is not available on it's own. You would have to order the complete new part to get it.
UPDATE: Spring part number is #20993734 which I think was superseded.
Silverfox
Old Feb 6, 2018 | 12:14 PM
The rear spring shows 22712222 as the part number , for LS and LT
https://www.gmpartsdirect.com/oem-pa...pring-22712222
