SS manual passenger Knuckle needed , got one!!
Picked up my 08 SS about 6 weeks ago now, long story short the steering wheel was WAY off to the right and it was sketchy AF to drive. I got struts for it, and took it to my garage. As soon as I jacked it up I could move the knuckle around a TON, they had the wrong LCA in it.... Phone call to the local dealer to find the nearest GM arm, and some frustrating moments getting that rear bolt out.... The new arm went in great, and at first I didn't think the knuckle was damaged but didn't rule it out. The wheel came back almost dead center and it drove pretty decent. I did also put new moog end links, new upper hats with bearings, and the insulator plates above the spring. I still need to do the drivers LCA, and sway bar bushings, but beyond that I'm not sure why it would still clunk in the right front. It also has new wheel bearings, so I just need a PASSENGER SIDE SS MANUAL KNUCKLE.
Hope one of y'all can help me out here!
When you replaced your struts, we're they fully loaded aftermarket, or just the struts? I replaced the struts on one of my 09 SS units and it still clunked. Found out through the "clunking" GM TSB that it was the strut jounce bumper. They loosen up on the shaft and the bellows / bumper as an assembly bounce up and down going over bumps. A couple of zip ties on the shaft to hold them up confirmed, so I bought new bumpers. GM says to glue the bellows to the spring seat to stop it from happening (bumpers sort of "clip" into the bellows).
Just a thought.
Robert
Just a thought.
Robert
Just a thought.
Robert
Just a thought.
Robert
Paul Theriault
15
Apr 2, 2018 04:44 PM
Matthew John Zeigler
14
Jan 20, 2018 11:34 PM
