Almost a new HHR owner!..some questions
I signed papers today for an 09' LT2. I held out for the bigger engine. Is there much difference between the 1LT and 2LT? I'll be using it mainly for deliveries and will be carrying between 600-1000lbs daily. What are the two or three best modifications I can make to handle the weight and improve performance? This is a real fun vehicle to drive! Thanx!
Thanx for your input. I was thinking along the same lines. Are there CERTAIN products you might recommend that has a consensus on this forum? I believe a certain sway bar is quite popular but are Cobalt springs or HHR SS springs the way to go? Thanx!
1000 lbs daily.. Wow !!! a member here knows of which airbags to put inside the rear springs to haul heavy..
https://www.chevyhhr.net/forums/members/igottawoody-5336/
Shoot him a Private message, he has all the details..
You certainly don't want cobalt lowering springs, sway bar yes.
Welcome. Aboard
Manual or Auto?
Over 95% of 2LTs are automatic, so yours probably is, too. If not, the short-shifter kit and weighted shift knob are wonderful. I agree with the rear sway bar. I have kept away from springs and lowering (despite everything else I did, see below). The less soft factory FE3 suspension on the 2LT rides fine for me. I also suggest getting dual horns as a safety issue. The single horn in the HHR is inadequate.
