Hello! From Tennessee!
Old Aug 15, 2025 | 11:04 AM
Gelfo's Avatar
Hello, my name is Paul
I am new kinda new here. I have been reading your post for a few years on and off and find them very helpful and entertaining.
I had a 2009 HHR SS that I bought new and totaled back in 2019. I had every intention of fixing it but had to move from Washington state to Tennessee.
I stripped it completely, kept everything except the body and rear axle and now bought a 2011 LT.
Now I want to build a clone.
who can guide me?
Thank you in advance for your help
Old Aug 15, 2025 | 11:25 AM
What do you mean exactly "clone"? If just looks the front and rear bumper covers and the grille and running boards/side skirts and badges and wheels. Then you can rip someone off by selling it as a SS.
The suspension and steering and brakes are not interchangeable. Switching engines would be cheaper and easier to just buy a SS.
Old Aug 15, 2025 | 12:59 PM
Gelfo's Avatar
What I mean is, I have the engine, trans, front suspension, brakes(except rear), all the wiring, computer, rack and pinion, steering column and even the abs system.
I'm not interested in it looking like a SS or selling it afterwards. I just want to use my SS parts and have a HHR that I can enjoy again.
I appreciate the question though.
Old Aug 15, 2025 | 02:08 PM
The SS parts will transfer over to the non SS body, you’ll need to uses the engine cradle from the SS , find a replacement SS rear axle beam or disc brake swap . The ECM and BCM and wire harness will have to be used as will the steering module , SS steering column and a bunch of other parts
theres nothing you can do that can’t be done! It’s easy!
Old Aug 15, 2025 | 03:06 PM
Gelfo's Avatar
Thank you Oldblue.
I appreciate the positivity. Has anyone on here done this that you know of?
Old Aug 15, 2025 | 03:27 PM
One that cloned an SS panel way back when, I visited him and bought the interior out of the 2LT donor car, he was going through all the boxes of SS parts , now when he did his parts were available that are obsolete now, 15 years later. He bought a rear SS panel that I was just about to buy, as far as I know he still has that also!
Old Aug 15, 2025 | 03:49 PM
Need Intercooler. The cradle and auto trans should be the same. Steering knuckles and ball joints and sway bar are different. Rack & pinion and steering column are different. Brakes and ABS are different. TCM and ECM are different. Exhaust system is different.
If you have the cradle attached to the engine/trans/suspension/struts it should be close to plug and play
Old Aug 15, 2025 | 05:47 PM
Welcome to the site.
My opinion is it’s more trouble than it’s worth trying to put SS parts in a LT. You say “clone” but it wouldn’t be.
I would suggest you find a SS in need of an engine or other major repairs. You could probably find one pretty cheap. You seem to have most of the mechanical parts for a rebuild of a SS.
Old Aug 15, 2025 | 08:15 PM
Gelfo's Avatar
Thank you All.
l will update on any progress and definitely ask questions along the way.
Old Aug 16, 2025 | 08:43 PM
PulpFriction's Avatar
There's a guy in Ontario that recently fully cloned a full panel with an SS donor and a white LS Panel body. Everything. Interior, bumpers, harnesses, suspension. A white SS is Striking. I always thought they shoulda offered the SS in white.Striking. He posts on a FB HHR SS group
JackyS
Feb 28, 2017 07:01 AM
lmazur2
Nov 28, 2014 01:09 AM
terryb44
Feb 24, 2012 10:36 AM
HURSTSS
Jul 16, 2011 10:02 PM
Mdbell06
May 31, 2009 09:32 AM
