Hhr?
Old Nov 6, 2012 | 08:38 AM
skyline26's Avatar
Originally Posted by Ron S
Welcome. We have 2 a 09 and a 10 and have had no none warrenty problems. There is a recall on the ignition switch just make sure it is done. That was my only real problem.
i bought my 08 used..so how do you know if the other person replaced the ignition switch or not? i havent had a problem with it and im at 60,000kms so im wondering if its been done or am i just lucky..
Old Nov 6, 2012 | 11:11 AM
07azhhr's Avatar
Originally Posted by 5speed4
Someone can correct me if I'm wrong, but I think the 2011 has Direct Injection and the 2008 does not. Could be good for an extra 1-2 mpg if that's important to you.
That is incorrect. Only the SS's 2.0 LNF motor have DI in the HHR's. But the engine in the 08 vs the 11's is different with the addition of variable valve timing and flex fuel found in the 11's (was changed in 09 or 10) that is not there in the 08. But it only increased HP by I think 10hp and a gallon or two more MPG's at the pump.
OP- All three could be a good buy or bad buy depending on how they were treated during their previous ownership(s) so be sure to check them out well. Also as with any car there were lemon trees mixed in with the apple trees back at the plant and some of our beloved HHR's have been found to come from those lemon trees.
Old Nov 6, 2012 | 11:12 AM
Very simple. Give the dealer your serial number and let him look it up.
Old Nov 6, 2012 | 11:19 AM
07azhhr's Avatar
Also known as the VIN number. the dealer might look at you funny if you say serial number LOL. Or Michelle aka member ChevroletCustomerService or member Chevymngr (admin) can look it up for you.
Old Nov 6, 2012 | 01:50 PM
5speed4's Avatar
Well shut my mouth, then. Thanks for the info and sorry to the OP for the incorrect info.
Old Nov 6, 2012 | 02:48 PM
Yep, I would be happy to perform VIN checks for people! Thank you, 07azhhr. How have you been?
Old Nov 6, 2012 | 05:06 PM
2007 LS 2.2 no major issues 109,000 miles great little ride I would go newest as there really is no change to the rides , and you'll get the longer period of warrenty
Old Nov 6, 2012 | 06:54 PM
07azhhr's Avatar
I have been good thank you. Glad to see you back. Your fill in was not the same as you .
Old Nov 6, 2012 | 06:56 PM
07azhhr's Avatar
It is ok. I thought the same in another thread and had to do a search and find that I was wrong lol. It happens.
Old Nov 6, 2012 | 07:01 PM
07azhhr's Avatar
That is a great point. The 08 is almost out of the powertrain warranty and IS out of the bumper to bumper one. If they are over 36k though they will be out of the b2b one. If they are at 30k but still have one then find everything you can fast lol.
I bought my 07 LS last year with just over 60k on it. Michelle found me how much remainder of PT warranty was left. It wasn't much and I did not need to use it so all was and is good but hey if you have the option of one with it then that would get my vote. To be clear I am refering to factory warranty.
