1952 Ford truck build! Suggestions?
Old Feb 15, 2009 | 10:22 AM
knightRS32's Avatar
This is a far cry from anything HHR, but then again, my HHR is a far cry from rubber melting fun!
I'm building a 1952 Ford truck rat rod to help keep the miles on my HHR down in the summer months. My questions are about the drive train...
I was given a S.B. Buick 350 and the truck has a Dana 44 rear end with a 3.90 gear. I'm putting a 4bbl intake and carb on it, so I should have about 280hp and 350 lb/ft of torque.
I want a 5 speed transmission, which one would you use? Would you stick with the current rear end, or get a different one? I have the option of getting a 1968 Buick 10-bolt with a 2.93 gear, should I get it and put new gears in it?
Any other suggestions are welcome!
Old Feb 15, 2009 | 01:39 PM
knightRS32's Avatar
After doing some research I think I'm going to buy an old Chevy S10 and use it's chassis and parts (steering, brakes, etc.)
Old Feb 15, 2009 | 01:55 PM
catdaddy137's Avatar
camaro 5speed
i think the camaro 5speed would be nice setup ,1990ish+. the ford rear will hold up better than the gm. if you don't build your engine up much , and don't drive like you're at the dragstrip everyday the s10 rear will be fine. and nice if it already has the disc brakes. if you can find a s10 with the 4.3 vortech , you could just change the body,steering,fuel , electric, and still have a strong engine. i have 98 isuzu-same as s10- , with 4.3 , it has plenty of power.
Old Feb 15, 2009 | 11:50 PM
btbowtie's Avatar
Sounds like a great project!
S-10 chassis is a pretty good platform for your ride. Some things to think about is wheelbase and track width. I think the front track width on s-10s are narrower than your 52 but some wheel spacers can take care of that for you. For the rear I found that the 4 wheel drive s-10s are wider and are closer to rear track width. If you find a long wheelbase or ext cab s-10 you could cut down for the right wheelbase.
If you don't want to mess with cab mounts, I have had pretty good luck with 71-81 camaro front clips and using the rear ends as well. If your up for some front frame grafting. On the rear use your leaf springs with a few removed for better ride and stance.
Good luck with your 52!
Old Feb 16, 2009 | 06:55 AM
halfpanel08's Avatar
dont use a buick motor.. lol. go SB or BB Chevy..
keep me up dated on this, im interested .. i LOVE rat/hot rods
im looking at gettin a 65-75 Chevy/Ford Truck for restore
Old Feb 16, 2009 | 08:16 AM
esmarkey's Avatar
Don't forget to get some pics.... before and after.
I think the Dana 44 with the 3.90 gears would be a good choice and should hold up well unless you plan on running way more power and slicks.
Old Feb 17, 2009 | 08:24 PM
knightRS32's Avatar
I found an S10 donor for $125...delivered! I'm going to strip it down to a bare frame, sand and paint it starting this weekend.
For now, I'm going to run the S10 rear end and if it breaks I'll find a rear out of a Fox Mustang and replace it.
As far as the SB Buick goes...They put out tremendous torque! Anywho, it's free and has 150,000 miles on it, so I'm using it as a temp solution until I build a better motor.
jaysif777
Jan 12, 2015 04:35 PM
Gordio
Nov 8, 2013 12:22 PM
matt gent
War Stories
11
May 26, 2013 03:14 AM
HillsdaleHHR
Oct 1, 2010 08:51 AM
HillsdaleHHR
Jan 4, 2007 08:40 AM
