How to "lock" an open dif
Old Dec 19, 2009 | 06:16 PM
c2vette's Avatar
So I thought this was fairly common knowledge, but after seeing many scenes of folks getting pushed while stuck in the snow, including a Jeep with snow tires spinning the left rear and right front tires, it evidently is not "common".
All you need to do is drag the brakes slightly and without going into the technicalities, it will cause torque to transfer through both (or all four) wheels even with an open differential. Used this technique to get moving in mud or snow many times.
Old Dec 19, 2009 | 06:55 PM
ballplr's Avatar
insall a spool, weld spider gears or install lockers
Old Dec 19, 2009 | 09:05 PM
prod's Avatar
Thanks for the tip. Common sense I guess, but it never occurred to me.
Old Dec 19, 2009 | 11:21 PM
masterchief1112's Avatar
i could have used that today while getting stuck in my rwd pickup. ended up having a farmer and his son push me out.
Old Dec 19, 2009 | 11:41 PM
c2vette's Avatar
Yeah, and for rwd only it works best if you just apply the parking brake slightly so you don't have the front brakes fighting you.
geg
Nov 25, 2020 12:52 AM
MidgetHurse-LT
Jan 25, 2015 11:24 AM
jerryshhr2
Jun 17, 2013 03:04 PM
Finch106
Jun 6, 2012 09:48 AM
c2vette
Nov 1, 2008 07:29 PM
