I need photoshop help!!
Old Dec 27, 2006 | 10:05 PM
I am trying to get just the car from a pic. Don't want any of the background.
Can somebody help me out? Might be a free t-shirt in the deal!
Old Dec 27, 2006 | 10:12 PM
karen1953's Avatar
Check with 06ChevyHHR or Deb.
Wait I think somebody said that they would help with photoshop.
Just a minute...........................................
try here if this is not what you need, you might pm fantomfreke https://www.chevyhhr.net/forums/show...ight=photoshop
Old Dec 27, 2006 | 10:15 PM
Already PMd Deb, no response yet. A little more skill needed than I've seen o6 do yet.
I don't have photoshop, so a tutorial won't help. Great ideas though, I forgot about that thread.
Thanks Karen.
Old Dec 27, 2006 | 10:16 PM
karen1953's Avatar
Sorry Good luck.
Old Dec 27, 2006 | 10:46 PM
courthousedeb's Avatar
Mike...I don't know much about Photoshop...yet. Just got a couple versions loaded on my new computers the other day and haven't had time to mess with them yet. I can sure give it a try if I can have a few days to work on it...but my forte is Paint Shop Pro and I'm not even sure if I can remove the background with that.
I'm sure if you need a quick fix, the thread mentioned above would be your best bet. Let me know and I'll do what I can being a Photoshop rookie.
Old Dec 27, 2006 | 10:56 PM
Thanks Deb. I didn't know how much if any experience you had with it. I've got a few weeks, nothing vital. I did post in the other thread so maybe I can get some help there.
thanks
Old Dec 27, 2006 | 10:57 PM
ivtech's Avatar
You can go around what you want with the magnetic lasso to select then copy and put on a new canvas or invert select and delect the background. You can also erase the background with the erase tool. Or use the magic wand to select the colors of the background and erase.
Hope that helps.
Old Dec 27, 2006 | 11:08 PM
It would if I'd ever used it or even had it! Thanks though, I do have access to it. I guess it's time to learn something new!
Thanks Charles!
Old Dec 27, 2006 | 11:30 PM
ivtech's Avatar
Gimp is free and is just like photoshop. You could give it a try.
http://www.gimp.org/windows/
Old Dec 28, 2006 | 12:04 AM
bdubsee's Avatar
I like to use Extract. Simply go to Filter -> Extract. You'll get a new window with a few simple tools. You basically highlight the edges of the area you want to keep and then fill it in. PS will then guess what to keep and what to get rid of. Play around with the different options until you get the look you want. Make sure to select 'Smart Highlighting' for well defined edges to speed up the process. It's much faster and more forgiving than the magnetic lasso (though if you use this, don't forget to adjust your tolerances to get just the right edges). The Help tutorial is PS is pretty good for Extract.
Disclaimer - This info applies to version CS2 - I don't know about previous versions. Also, I use Mac OS X 10.4.8. If you are using something else, it may be slightly different - the Help tutorial should help you in this case.
BTW- I have media access for GM if you need any high-resolution images to work from. Just send me a PM with your request and I'll see what I can get for you.
