Need Help With My Harley
ok so after 2 weeks of waiting i finally get my idle/throttle and brake cable's in so i can finish my mini ape install. i get her all buttoned up and turn the ignition on. all good so far. She turns on, headlight, tach, etc all come on. I continue on...i hit the "RUN" switch.....nothing. no familiar sound of fuel moving, no little engine light on the tach...nothing. I try the right blinker switch...again nothing. Now keep in mind i did not have to extend any of the electrical wires as they were long enough to reach. the left blinker, horn switch, etc all work. Anybody have any ideas? Is there a power or ground wire that runs into the housing that maybe got pinched or ripped? any help or suggestions would be appreciated
If it's not turning over then it sounds like what you said already and there is a problem getting juice to the starter. I would start there.
Good luck |
clutch safety
do harleys have a safety , that you need to hold the clutch??? my kaw does , and sometimes i forget.
You have a problem in your right side handlebar wiring. Can you pull that side off and make sure nothings disconnected?
Originally Posted by Blackedout97
(Post 366882)
If you'd prefer, give me the model and year info and I'd post the question for you. http://www.hdforums.com/ |
Here are 2 more forums you could also try. They are great at answering questions. Hope this helps.
http://xlforum.net/vbportal/modules/Jig/index.php http://harleytechtalk.net/htt/index.php |
Originally Posted by InkTheFlesh
(Post 367030)
multiple problems on the same side.....yup,needs to come back apart(right side only)..possible you pinched some wires maybe shorting them....also recheck the fuses...
Are you sure you didn't pinch any wires when you bolted up the controls to the bars???
