Need Help With My Harley
ok so after 2 weeks of waiting i finally get my idle/throttle and brake cable's in so i can finish my mini ape install. i get her all buttoned up and turn the ignition on. all good so far. She turns on, headlight, tach, etc all come on. I continue on...i hit the "RUN" switch.....nothing. no familiar sound of fuel moving, no little engine light on the tach...nothing. I try the right blinker switch...again nothing. Now keep in mind i did not have to extend any of the electrical wires as they were long enough to reach. the left blinker, horn switch, etc all work. Anybody have any ideas? Is there a power or ground wire that runs into the housing that maybe got pinched or ripped? any help or suggestions would be appreciated
If you'd prefer, give me the model and year info and I'd post the question for you.
http://www.hdforums.com/
Here are 2 more forums you could also try. They are great at answering questions. Hope this helps.
http://xlforum.net/vbportal/modules/Jig/index.php
http://harleytechtalk.net/htt/index.php
All the wires look good, that is what i can see of them until they run up under the tank. its looking like im going to have to suck it up and take it all apart again and see whats going on.
Lethal Tendencies
13
02-03-2010 04:04 PM
