02 sensors! again!
well she cooled off...LOL
and i looked at the overfill did not seem promising. so i opened the line to burp the radiator. guess what i dunt see any coolant!
so i may have a leak? the thermostat sticks in the open position correct? or can it be closed as well? i will replace the thermostat no matter what.
i have never seen anything leak from this car, except that oil leak i had last year. so i tend to feel the thermostat is stuck closed.
as usual you guys are on the money!!! THANK YOU
any other suggestions for this?? it is not a difficult job.i wonder if the store is still open? it is almost 7 here.
Rare occasion it could stick closed, theoretically, anyway. Would cause an overheat condition, not what you're experiencing. They stick open, and cause the P0128.
Like Oldblue said, ACDelco 131-158 is the only thermostat you should be buying, any others cause problems.
I have one in my 2011, 2.4 2LT , it fits and works much better then the junk the PO had in it and the orange Dexcool is much better at warming up to computers expectations then the green stuff , he had in it , he claimed it’s all the same and cheaper. Bollocks! It had P0128
ok. my darn local auto parts stores do not stock the AC part!! so i will need to order from amazon. they can have it here by sunday!! but the price is comparable to rock. i just cant use that discount that you mentioned!! oh well!!
ok on the orange dexcool i will ask if advance has it. THANK YOU!!!
