08' HHR Flex pipe replacement
Hello everyone. Been lurking here for a while and have gotten solid info concerning the HHR platform exclusively from this group and YT. I came across a used 08 LS 2.2L for a good price, the owner told me the motor was shot. Checked it out, ordered a long block replacement to drop in. She's ready to come out *BUT* I admittedly have been saving the exhaust disconnections in the back for last for two reasons, one of which I learned about from this group:
The nuts/studs are not budging, I can see my classic move I've done on other flanges where I muscle the nut then it miraculously gives finally and I see a broken stud poking out of the socket on the drawback (*sigh*) An 08' flex pipe section (doesn't look like anything back there has ever been changed) just doesn't sit right with me mating it up to a new block. Since the nuts are not budging off the flange, should I just order a new flex pipe section, saw the pipe off about an inch down from the weld to give me and acceptable margin for the replacement, and go for a new manifold also? I have MIG and TIG sitting right here, ready. Haven't seen a crack in the old one yet, but I suspect it won't be long after bolting everything back together that this might develop. Thoughts? |
Welcome to the site, soak the three nuts and bolts with PB Blaster or your choice of penetrating oil. Use a six point deep socket the correct size, 15 MM , an extension and a 24 inch breaker bar.
Long block would imply includes exhaust manifold, to me.
However, a new flex pipe is probably a good investment. There are several options, I would get one that has the bend in it, they come short and long. The long ones are easier to deal with. |
Originally Posted by donbrew
(Post 903139)
In the ZZP and Pace websites, the photos show an intake manifold is included, but I don’t see the exhaust side to confirm if a manifold is included.
ZZP, intake is not included. Exhaust is not included either, however, if you order a new turbo with it, the manifold might be included(all assembled). Valve cover and oil pan are included.
RJ, we’re discussing a 2.2 here! Not the turbocharged 2.0
https://zzperformance.com/products/l61-2-2l-long-block https://zzperformance.com/products/ldk-long-block |
Whoops
Hey everybody, thanks for replying, literally 5 min after I posted here, walked back to the bay (I presoaked the studs/nuts one last time earlier in the day) tried it again for the hell of it and got budges on all three, studs and nuts in a labeled bag right now. I still think it might be a good idea to go with a new flex at this point, I'm just getting free time to go back there again and pluck her out to check the exhaust manifold, I'll keep this thread updated
Could just replace the whole downpipe, no welding required.
