2009 hhr
Old Sep 17, 2018 | 01:10 PM
Nellie's Avatar
Talking 2009 hhr
Hello,
I have a 2009 HHR, we had a rattle in the front end, and it sounded like an airplane taking off when we would drive so started getting the front end worked on, we had the wheel hub's bearings replaced this took care of the airplane noise, the sway bar bushings upper and lower have been replaced, now we have a squeal when the steering wheel is turned, I'm thinking inner ti rod end, hubby's not so sure so why I'm here asking what y'all think??
Old Sep 17, 2018 | 01:27 PM
Nellie's Avatar
and the control arms were replaced
Old Sep 17, 2018 | 02:57 PM
So where is the squeak heard from ? Inside the car or can you hear it when standing outside ?
If inside: Lower end of the steering column has a small "u-joint" in it. Could be where the squeak is from. A little squirt of lube may quiet it down for a while.
If outside: Could be just about any part of the suspension that rotates with steering. Strut bearings would be where I'd look 1st.
Old Sep 17, 2018 | 04:09 PM
Nellie's Avatar
It's coming from outside, he looked at the tie rod end boots and says it looks fine no cracks or rips.. and it doesn't make any sound when the car is parked just when going around corners, to us sounds more like a friction squeak so wondering if it needs grease
we have been driving it about 6 years now, and the front end issues have been the first thins we have had to have worked on
Old Sep 17, 2018 | 04:42 PM
Hmm. Brake pads maybe ?
Simple test. Going around the corner, when it starts squeaking, step lightly on the brakes. If it stops the noise, then you've got brake pad issues. Either worn out or loose pads in the calipers.
Old Sep 17, 2018 | 05:21 PM
Nellie's Avatar
He doesn't think so since the sound stays the same weather he presses the brake or not, he drives more then I do cause he takes it to work I noticed the sound when I went some ware with him on Saturday, He's like yeah it's been doing that all week and asked me to look it up so here I am :)
we had the pads and rotters replaced at the same time they did the wheel hub assemblies, also the manic told him at the time that he might need to grease the tie rod ends and showed him ware to put it in, so hes thinking that's what it is since he never did it and needs to buy a geese gun, and sites are saying that's a possibility
Old Sep 17, 2018 | 06:02 PM
Has anybody actually looked at the disk pads? They have wear indicators that squeal when you are out of friction material; even when not applied.
Old Sep 17, 2018 | 10:11 PM
I've told you other things to check but you keep saying no, it must be the tie rods. If that's the only thing you think it could be then just shoot some grease in there and see if it fixes the squeak. (Doubt it will)
FYI. Tie rod ends turn(rotate) very little when the steering is turned. The chances of them producing a squeak like you described are very slim.
Old Sep 18, 2018 | 07:28 AM
Ohiocruiser's Avatar
Intermediate steering shaft, pinion rack, strut mount bearing. You can keep throwing parts, or get a mechanic to fing the problem.
Old Sep 25, 2018 | 10:42 AM
OldSwede's Avatar
In my experience with automobiles with front McPherson struts, the upper strut bearing is the culprit.
HeartGirl
Nov 21, 2011 12:34 PM
