2010 Chevy HHR LS Trouble lights
Old Aug 17, 2019 | 04:12 PM
Charvel1975's Avatar
Question 2010 Chevy HHR LS Trouble lights
Trouble lights that recently came on at 135,797 miles on my HHR: ABS and Traction control lights
Flashing messages: Service ESC, Service Traction
Sticker from my Chevy dealer says: Next recommended Service: 11/13/2019 or 138,395 miles
My HHR has never had the 100,000 mile manufacturer recommended service or tune up either. Any thoughts on what may be causing these error lights to come on?
Old Aug 17, 2019 | 04:18 PM
No. 100,000 mile checkup is BS. tuneup is new plugs at 100,000 miles. Any visit to a dealership besides warranty or recall is uncalled for.
Is the check engine light on?
Old Aug 17, 2019 | 04:26 PM
Your 2010 HHR might have several things happening , if the CEL is lit, have the codes read at your local parts palace.
please write down the codes and post them here , like P0010.
if you go to the parts palace have them check the charging system and load test the battery.
our trucklets don't like a weak battery
Question
No the check engine light is not on although it has come on and off in the past recently. Should I get a tune up now that I'm over 136,000 miles?
Old Aug 17, 2019 | 04:29 PM
When the check engine light came on back in May of this year I believe it was, my friend had a code reader he let me borrow and it was throwing out the following codes:
P0103 - Cam Shaft Solenoid
Cam Exhaust
Old Aug 17, 2019 | 04:31 PM
Don't worry about a "tune-up" at this time. Find out what's wrong with it, fix that, then worry about it needing more preventive maintenance...
Have the codes read and report back
Old Aug 17, 2019 | 04:35 PM
P0103 is for the MAF , check it maybe it’s not firmly plugged in.
https://www.obd-codes.com/p0103
could it have been P0301 ?
We can guess or , you could borrow the code reader again.
a set it plugs wouldn’t hurt at this point.
don’t forget the discount code! At RockAuto
Old Aug 17, 2019 | 04:52 PM
I'm sure it is P0013. You need to replace both VVT valves. If you can use a screwdriver you can do it.
A tune up consists of new spark plugs every 100,000 miles get only ACDelco Iridium plugs.
Old Aug 21, 2019 | 02:59 PM
Tokin's Avatar
Ive seen bad front wheel bearings make the abs light come on and then go back out. 100,000 is about when they needed replaced on my roomies 2010.
Old Aug 21, 2019 | 04:09 PM
A random P0013 bad VVT valves will cause the TC and service ESC. Yes, could be a wheel hub; while the ABS light is on you can have the ABS codes read it takes a capable reader; that will tell you which one and what.
Charvel has a habit of asking questions then coming back with the same question 6 months later.
