ac compressor clutch
Old Mar 24, 2019 | 10:40 AM
Cliffs51's Avatar
Has anyone successfully replaced the ac compressor clutch with the compressor in the car and connected. Id like to change mine without opening up the system. Thanks
Old Mar 24, 2019 | 04:14 PM
Cat Man HHR's Avatar
You can change just the clutch and not worry about opening the system.
Question is ? Do you have the correct puller/installer for it ?
Old Mar 25, 2019 | 03:26 PM
Cliffs51's Avatar
From looking at youtube looks like i need snap ring pliers and two different types of pullers. Am I right? Is there enough room to use the pullers? I think i may replace the whole clutch instead of just the bearing.
Old Mar 25, 2019 | 03:45 PM
You will at least have to disconnect the compressor and pull it up with the hoses attached to give yourself room to work. Once you remove the center of the clutch with a puller (yes you might need that snap ring pliers) you can then remove the 4 bolts and remove the coil magnet. The bearing is part of the coil assembly. Buy a new assembly and save the shims from the old one if there are any. That will set the air gap between the clutch face and magnet.
I'm sure if you go to AutoZone or Pep Boys or Advance you can rent the puller group.
Good luck with the repair.
Old Mar 25, 2019 | 07:37 PM
Cliffs51's Avatar
Thanks for the help 😁
mistermike
Sep 11, 2008 10:22 PM
Lone Ranger
Aug 9, 2007 10:08 PM
MCANAW
May 16, 2007 06:43 PM
coolsurf
Sep 3, 2006 11:03 PM
jerij
May 30, 2006 10:58 AM
