Adjusting headlights
Old Mar 25, 2013 | 12:12 PM
tntwolt's Avatar
are the headlights "adjustable"? i put a new bulb in and that gets me flashed by oncoming traffic.
Old Mar 25, 2013 | 12:18 PM
LawDog88's Avatar
They are adjustable, yes. There is a screw on the back side of the housing. This is what you will be looking for.
Old Mar 25, 2013 | 12:20 PM
db/sb's Avatar
MeijerLPO beat me to it so I'll just add that if you turn that screw clockwise it raises the beam and if you turn it counterclockwise it will lower the beam. The complete headlight aiming procedure is outlined in your 2009 owners manual; page 5-44 to 5-46.
Old Mar 25, 2013 | 12:23 PM
LawDog88's Avatar
Trial and Error db/sb I will soon have to be adjusting mine, as I just picked up some new shocks/struts for my HHR and will be lowering it soon!
Old Mar 25, 2013 | 12:32 PM
Fwiw. If you lower it about the same front/back, you shouldn't have to adjust the headlights. The change in the headlights will be almost none.
Now if your headlight aim is off before you lower it,.... then yes you'll need to adjust them.
Old Mar 25, 2013 | 12:34 PM
solman98's Avatar
Odd that changing the bulb would start you getting flashed.
Old Mar 25, 2013 | 01:48 PM
LawDog88's Avatar
Different type of bulb, or an upgraded bulb that is brighter could..
also, FMG, I am lowering and leveling.
Old Mar 25, 2013 | 05:18 PM
after you lower and level your ride, adjust the lights, mine worked out to 3/4 turn down
Old Mar 25, 2013 | 09:31 PM
LawDog88's Avatar
Thanks Blue
Old Mar 25, 2013 | 11:09 PM
Allow springs to settle, prior to adjustment.. More precise that way.
Kev, since you swapped headlights to depos, yours should be checked reguardless.
