Article "Ignore that check engine light at your own peril"
Old Sep 11, 2014 | 12:04 AM
Ignore that check engine light at your own peril | Driving
Old Sep 12, 2014 | 03:00 AM
A good find whopper!
And a statement that should be printed on every instrument cluster.
Old Sep 12, 2014 | 06:22 AM
The top of his list is "critters chewing" on things!
Old Sep 12, 2014 | 09:35 AM
And yup, I've encountered that problem. Pesky lil varmints!!!!
Old Sep 12, 2014 | 11:18 AM
Doc brown's Avatar
The best advice in the article is to get your own code scanner. Just knowing the code can go a long way toward having an idea as to how quickly you should resolve the issue.
Rule of thumb: If the light it solid and the car is running smooth, you can keep driving with the idea of getting it check soon. If the light is solid but it's running rough, get it looked at right away. If its a flashing light, pull over and shut it off.
whopper
Jan 19, 2012 02:54 PM
menance
Dec 22, 2010 06:14 PM
beachbum1970
Mar 25, 2009 08:46 PM
XXL
2.0L Performance Tech
Sep 1, 2008 03:05 PM
NHHHR
Jun 5, 2007 10:08 AM
