Atf
Old Oct 25, 2012 | 09:37 PM
bugflipper's Avatar
Atf
When should you flush out the old atf? I am assuming they have the sealed setup that most of the new cars are going to where you have to take it to the quick lube?
Thanks
Old Oct 26, 2012 | 12:38 AM
Under Severe service @ 50K, otherwise 100K, But I don't think I would let any quik lube jockeys do this.
Edit: Yes it is a sealed unit, & no dipstick..
Old Oct 27, 2012 | 03:15 PM
bugflipper's Avatar
How would I do it at home? Of coarse I would drop the pan and change the filter. But where does the new ATF go? Assuming there would have to be a plug to add it. I do have an old electronic fuel pump for fluid transfer. I just went over 100k so figured it would be time.
Thanks
Old Oct 27, 2012 | 04:01 PM
Thanks
Use the Search tool, there are a few threads about changing the ATF. Yes there is a plug; top of trans driver side (for fill only tho); Level control hole on pass. side (like old fashioned differential). PM me if you need a Shop manual, or go to the local AutoParts store I understand that there is a Haynes book now.
Old Oct 27, 2012 | 06:21 PM
bugflipper's Avatar
Much appretiated.
Old Nov 9, 2012 | 05:57 PM
Radco's Avatar
I am a future 2011 owner, So sorry for the dumb question. If ther is no dip stick for the tranny how do you check it? I will buy a manual if the deal goes through tomorrow :)
Thanks
Richard
Old Nov 9, 2012 | 05:59 PM
swerv0428's Avatar
no need to check it since it is sealed.
But if your buying a manual then you aint gotta worry about it.
Old Nov 9, 2012 | 06:18 PM
Radco's Avatar
Good to know Thanks, Im trying to get as much info as I can ,even if the HHR is not inmyu hands yet :)
Old Nov 9, 2012 | 09:27 PM
swerv0428's Avatar
completely understand. I sold mine but i had 75,000 trouble free miles on mine. use the search feature and look over a bunch of posts. There is so much information on this site. you can learn a lot just by reading. Good luck on your search.
