Brake fluid reservoir
Old Apr 6, 2015 | 08:52 AM
The other the day I noticed some fluid on the driveway were I park my HHR.
The only fluid I found to be low was my brake fluid, my pedal pressure is fine, good solid feel, no low pedal when the brakes are pressed into service.
I did a search here but can't find any directions on how to change the reservoir !
I did find the TSB about the cold weather affecting the brake fluid and the part number for a kit to replace the reservoir GM Part # 15939572.
From what I see I need to remove the fuse panel and then the master cylinder to move it forward to clear the air conditioner plumbing then remove the retainer bolt to pull the plastic tub up and spill brake fluid onto the paper towels I'll place under it
Any I site into this would be a great help! I can't lean over the fender for very long to do this!
Old Apr 6, 2015 | 08:57 AM
First be sure it's leaking. The level drops as the pads wear and the caliper pistols extend.
Second you have to remove The fuse box to get to the MC. I think the reservoir just sits on an O-ring. Give me some time to be sure.
Old Apr 6, 2015 | 09:01 AM
I checked the pads, they only have approximately 2,600 miles on them. rear brakes are adjusted. I called two GM dealers parts guys I have worked with for over 30 years , they both said they have never had one in inventory or sold the GM Part # 15939572 kit. or put over the counter for warranty
Old Apr 6, 2015 | 09:14 AM
There is a pin or screw accessible from the driver side bottom of The tank, then 2 O-rings.
I would think a leak would be from the O-rings not a busted tank.
Old Apr 6, 2015 | 12:18 PM
I ordered the tank kit , it provides the orings and low fluid sensor.
Old Apr 6, 2015 | 06:23 PM
Steve. Got a part number for that kit ? It might be one we should add to our parts numbers sticky.
Old Apr 6, 2015 | 07:02 PM
The part number for the kit is in post #3.
Rjj
Oct 22, 2017 08:56 AM
bad03xtreme
Maintenance and Upkeep
13
Dec 19, 2014 06:23 PM
hozer
12
Mar 16, 2014 07:06 AM
fastsuv
Feb 22, 2013 10:36 PM
Major_Spittle
Apr 20, 2012 10:17 PM
