Charcoal Canister Seal
So this code has 0 to do with smog or how the car runs or anything like that? I thought this had something to do with the massive cloud of smoke from the exhaust or the foul odor inside the car which smells like foul exhaust.
What are your symptoms?
other than the code and "check gas cap" message on DIC, foul exhaust odor, cloud of smoke from exhaust after 3k rpm pull...however does not smoke at all on the freeway...
The smell could be from the EVAP.
The VENT valve might cause problems while filling the fuel tank.
The Purge valve has nothing to do with a vacuum leak and nothing to do with idling after a fill up event. It might cause a hard start and/or P0171/P0172.
Exhaust fumes in the cabin is not a minor problem, things like death could result.
I don't know which basket case hhrumadbruh is talking about, so I don't know it talking about the flex pipe is warranted.
