Charcoal Canister Seal
Old Apr 19, 2019 | 05:13 AM
Cat Man HHR's Avatar
Originally Posted by Jon Wamsley
I actually solved it with dipstick tube grommet.
Dipstick grommet from what year car/transmission ?
Old Mar 24, 2023 | 11:41 AM
hhrumadbruh's Avatar
So this code has 0 to do with smog or how the car runs or anything like that? I thought this had something to do with the massive cloud of smoke from the exhaust or the foul odor inside the car which smells like foul exhaust.
Old Mar 24, 2023 | 11:59 AM
greg8453's Avatar
What code? Evap?
This post is old.
Old Mar 24, 2023 | 12:04 PM
Originally Posted by greg8453
What code? Evap?
This post is old.
P0455 - large evap leak.
I've got a few things going on with the car but it sounds like it doesn't really relate to exhaust clouds or smog?
I'm not an expert so just trying to figure it out....
Old Mar 24, 2023 | 12:40 PM
It does have to do with emissions. The fuel vapor type, not exhaust gases. And it does affect the efficiency of the engine.
Old Mar 24, 2023 | 04:38 PM
greg8453's Avatar
If the purge valve is the leak it will not idle right. Especially after fueling up.
What are your symptoms?
Old Mar 24, 2023 | 06:55 PM
other than the code and "check gas cap" message on DIC, foul exhaust odor, cloud of smoke from exhaust after 3k rpm pull...however does not smoke at all on the freeway...
Old Mar 24, 2023 | 09:54 PM
greg8453's Avatar
You have just the one code for large evap leak? That is not causing the smoke under load. Are you consuming oil? Does the car accelerate OK?
The smell could be from the EVAP.
Old Mar 24, 2023 | 10:32 PM
The VENT valve might cause problems while filling the fuel tank.
The Purge valve has nothing to do with a vacuum leak and nothing to do with idling after a fill up event. It might cause a hard start and/or P0171/P0172.
Exhaust fumes in the cabin is not a minor problem, things like death could result.
I don't know which basket case hhrumadbruh is talking about, so I don't know it talking about the flex pipe is warranted.
Old Mar 24, 2023 | 10:59 PM
There are a few jury rigs mentioned, in this very thread even!
