Charge a/c
Old Jul 20, 2018 | 08:36 AM
J W Davis's Avatar
Originally Posted by Cat Man HHR
Why? There are no high and low pressures shown.
Find out before you overthink the wheel.
K.I.S.S.
His quote stated that the pressure would equalize after turning it off, he did not say what the pressures are. Until he post those pressures...it is all a guess. Since the system only holds .9 pounds, it is very easy to over fill and flood the evap preventing the Freon "flash over" that provides the cold evap.
Seen it many times, all kinds of equipment. like I said, just guessing without actual pressures.
Old Jul 20, 2018 | 08:54 AM
Scorangehhr's Avatar
Ac
I will try to get them today.
Old Jul 20, 2018 | 12:36 PM
Cat Man HHR's Avatar
A system should equalize it's pressures when not in use. But it could be 40/40, 60/60 or more.
Knowing ambient air temperatures and the low and high side pressures when in use can help in the diagnosis.
K.I.S.S. = "Keep It Simple Stupid"
Old Jul 20, 2018 | 02:59 PM
Ac
Thank you, I look into it in a few. I did bleed some off yesterday and drove about an hour. It did cool down in the 93 degree temp here in Atlanta. Mostly when stopped in traffix or at a steady speed at about 40, or 65. But it did go warmer but not hot. I will be getting pressures in a while. Although I will be quessing as to how much refrigerate is in the system. I thought it might just be easier to vacuum it out and put 14.4 Oz back into it. (.9 lbs).
Old Jul 20, 2018 | 03:13 PM
Might be if you know what you are doing.
filter, PAG, vacuuming correctly etc.
Old Jul 20, 2018 | 03:53 PM
If you're going to post up the pressures, you need all the stats.
Static pressure-gauges hooked up, nothing running.
Working pressures, high and low with AC operating.
Outside/ambient temperature
FYI. I wouldn't post up anything about "bleeding off" freon into the atmosphere.
The EPA feds may come to see you.
Old Jul 20, 2018 | 04:25 PM
This is why:
Old Jul 20, 2018 | 04:31 PM
Ac
No I take to get the system properly discharged. It is easier to say bleed.
Old Jul 27, 2018 | 05:58 PM
Hmm. To have it properly discharged it has to be connected to a recovery machine. Those have gauges so you should have been able to see what the pressure readings were when you bleed some off.
edit. I'm starting to doubt the validity of this story. Since the OP hasn't returned in a week now, we either scared him off or it wasn't what it originally appeared to be.
Old Jul 28, 2018 | 01:03 PM
tiapetra's Avatar
Or he just found his answers/fix elsewhere
HillsdaleHHR
Mar 17, 2007 10:50 AM
giant96
Jul 14, 2006 11:23 AM
SIHHR
Dec 21, 2005 06:33 PM
lou
2.4L Performance Tech
Nov 8, 2005 03:15 PM
