Cleaning Engine??
Old Aug 27, 2010 | 02:23 AM
TiggersHHR's Avatar
Cleaning Engine??
Call me crazy - not only do I like to keep the outside of my HHR clean, but I like to keep it clean under the hood. I need to find out the best way to clean the dirt and crud off my engine. Is there a special cleaner that I need to use? Can I use a power washer on the engine to clean it? I have also noticed some oxidation on the valve cover - How do I get rid of that? Any help would be appreciated.
Old Aug 27, 2010 | 04:31 AM
SHADOW(IN)'s Avatar
I would'nt use a powerwasher, could damage the electronics, I also have been looking for an easy way to clean the engine before a show. I'm useing a spray bottle with water.
Old Aug 27, 2010 | 05:59 AM
hyperv6's Avatar
Wipe down regularly.
A little white lightning degreser and a careful use of water from a controld hose has worked for me. Dust is more of an issue than anything.
I also use a lot of detailer and rags to clean most of the underhood areas.
Just don't use a pressure washer or put cold water on a hot engine. While you may get away with it this is no longer worth the risk to what damage it can do.
Old Aug 27, 2010 | 08:44 AM
jay loukakis's Avatar
Simple green works great just wash off and blow dry.
Old Aug 27, 2010 | 10:50 AM
Putter's Avatar
I use Mean Green....like $5 a gallon.
Old Aug 28, 2010 | 02:36 AM
TiggersHHR's Avatar
Thanks for the advice. I will most likely use a soft bristle brush to help get rid of the oxidation/corrosion on the valve cover. Is there anything that can be sprayed on the valve cover to inhibit the corrosion?
Old Aug 28, 2010 | 11:23 AM
ChevyMgr's Avatar
Detailers use pressure hoses on engines, but stay away from critical areas. That doesn't mean that 1 out of every 500 or so doesn't have a problem created because of water intrusion on a connector or what not.
I pressure wash mine while the engine is running. I just don't put the pressure in areas that I know I shouldn't.
As far as oxidizing I don't have any help on that.
Old Aug 28, 2010 | 12:02 PM
hyperv6's Avatar
That is the problem here how many know what they can wash and how many think they know what they can wash. Just not everyone here is a gear head or a up to date trained mechanic. Times and cars have changed much for many.
It may be best to recomend to either not use pressure washers or take it to a pro. Those who know what they are doing already know what can be done. I would hate to get someone in over their head.
Like you stated even the pro's screw up too.
Old Aug 28, 2010 | 12:09 PM
ChevyMgr's Avatar
Tiggers,
Come on down to Dallas for this years Super Bowl. I'll do a demonstration for you.
Maybe you should get your cam cover powdercoated.
Old Aug 28, 2010 | 07:28 PM
Kev&Chers{SS}'s Avatar
Ive always used simple green then rinse gently with controlled spray from hose. Then detail after dry with Armor all for all the black & most surfaces. No problems. So far with SS just some wipe off and Armor all & looks very sweet.
