Coolant Flush
Old Apr 8, 2022 | 08:50 PM
Yes since the rad is lower than the engine, best to raise the front for air to travel up to highest point..
Old Apr 9, 2022 | 10:56 AM
PulpFriction's Avatar
You don’t need to burp out the last tiny bit of air. A few thermal cycles will expel it and suck coolant from the recovery tank in its place.
Old Apr 9, 2022 | 06:44 PM
nicolade1976's Avatar
Thank you all so much again. Everyone's advice was spot on. I think the burping helped big time. My HHR is running beautifully, right at about 190 F under normal driving. I am pretty sure my thermostat was not working properly all along (I bought car with 129,000 miles on it) because I never remember seeing temp go above 175 F before. Also, I wanted to comment on mixing Dexcool with regular green Prestone. So, I had my collection bucket that I used to collect coolant from the last vehicle I flushed (1998 Saturn SW2), which had the green coolant. As soon as I added my discarded Dexcool to it, I instantly saw solids appear in the solution. I am pretty sure I saw someone comment about this before, but just from the visual evidence, I would say that I will never let the green stuff near my HHR (just for sake of not letting it react with residual Dexcool in my system). Probably better, if you get in a pinch to just add water until you can flush system and get the right concentration of Dexcool back in the system.
I didn't like the looks of it, so I changed. Seems like running temperature is higher now.
Old Apr 9, 2022 | 06:58 PM
Did you install a 180 degree AC Delco 131-158 thermostat?
Old Apr 9, 2022 | 07:11 PM
Yes. The temperature generally fluctuates between 185 to about 200 but mostly sits right around 190 when I am running down the road. Plus, the lower radiator hose has definitely gotten nice and toasty after I have run around town a little.
Old Apr 9, 2022 | 09:05 PM
Good to know, I always worried any voids in cooling system could cause hot spots..
Old Apr 10, 2022 | 12:03 PM
When Dexcool overheats it produces white chunks. If it has those chunks it is worn out.
Old Apr 10, 2022 | 08:56 PM
Thanks Don- I've never had anything remotely like that..
i dont know
Maintenance and Upkeep
Sep 17, 2017 05:06 PM
slonny
Nov 7, 2016 06:30 AM
anthonybeatz22
Apr 23, 2016 04:42 PM
Zagohhr
28
May 6, 2012 09:49 AM
