Coolant issue.
Old Feb 28, 2023 | 02:39 PM
greg8453's Avatar
Originally Posted by Maxifulmax
Final question, so hypothetically if the car hits something hard going fast or accelerates from 20 to 70 miles per hour. Would that cause the sensor to go haywire? Or did it just straight up die?
Have someone watch while you do some wiggling of the wires.
Old Feb 28, 2023 | 03:13 PM
Maxifulmax's Avatar
Is it possible that the thermostat is installed upside down, would that cause this issue? Just spitballing.
No, installed it correctly and it worked for 2 days. The gauge went to (- - -.) Reading when I accelerated hard onto the highway. It immediately went from 180F to 0F and has not gone up since.
Old Feb 28, 2023 | 06:24 PM
Sensor has passed on ! Sadly, you’re gonna have to get a new one
Old May 18, 2026 | 08:59 AM
KrazyFokcer's Avatar
Yep, sounds as if your sensor has bit the dust. I just did both in mine because of such codes. As said before, a 19mm deep and a flex ratchet, comes outside quick and easy. Good luck.
Jit
Oct 17, 2019 03:57 PM
mrmarkuSS
Oct 20, 2017 09:11 PM
kornellred
Maintenance and Upkeep
Nov 28, 2011 12:28 PM
fastsuv
Nov 28, 2011 11:40 AM
Dredd9799
May 17, 2009 12:51 AM
