Engine Tune Up Questions
Fixing O2 sensor problems is pretty important, because your flexfuel car needs that data whether it's eating E85 or not.
P0455 is just the P0442 graduating from a small evap leak to a large one. It can be a pita to find, but going large should make it easier. There is a TSB on the subject, if you think a long list of places to look for the leak will be helpful. I mentioned a link to it in a recent post.
But there's a good chance it's a corroded evap line somewhere between the tank and mid-cabin, near the wheel in particular. The evap and fuel line run together. They both corrode at the clips and inside the little insulation blankets.
Any gas smell? If you see much corrosion, you could just replace both lines. They'll leak eventually. Replacement just from the tank to mid cabin often will suffice. Nylon lines are easiest. There's an "Inline Tube" brand kit. I no longer like it. Fit problems.
Once you replace the thermostat Donbrew mentioned, be sure to get all the air out of the cooling system.
C0040 could be just a loose wire or bad connector for the RF wheel speed sensor. Could be the cause of the other C code?
Have not changed oil yet; it appears clean on the dipstick and is full. I am hoping to get more done in the spring when Minnesota weather improves.
This evening, it was hard to start. It required quite a bit of cranking. It is always something. I am not sure about E85 fuel; this is the first vehicle I have had that is made for it.
#2 O2 Sensor
You need a new #2 O2 sensor
A new ACDelco 131-158 thermostat. That part number only. That is why the gauge doesn't work.
A new EVAP vent valve
Possibly check for a rust hole in the EVAP tube in front of the driver side rear tire.
New front hubs. Maybe somebody disturbed the right front ABS wire during the brake work.
There is some problem between the EBCM and the ECM, probably a wire connection
Don't agonize over the torn air hose, it can be repaired with metal duct tape or replaced with 3" (I think) vent tube from HomeDepot.
The P0300 is probably a product of all of the above.
I don't know what they think is the difference between primary and secondary codes;.Codes are classified as current, pending or stored/historic.
2) I looked at some YouTube videos on HHR 2.2 O2 sensors; they refer to upstream and downstream. Is #2 downstream?
Thanks
Just a matter of a few rusted bolts, there are several way to go. New catalytic converter, new flex welded, new flex clamped. If you pay someone to do it they are all about the same price. Easiest is a new cat/downpipe 5 bolts and 2 O2 sensors. Cats on eBay run about $100-$150, shop labor about an hour.
Exhaust Leak
Next I need to determine the source of the exhaust leak. On an older Chevy pickup, I had an O2 sensor leaking exhaust, but probably not this time.
Could the exhaust leak be causing the O2 sensor to not be working properly without itself being defective? Could the opening be adding some air to the exhaust mix? Thanks
