Gas mileage drop after air filter install
Old Aug 30, 2015 | 10:08 AM
I recently change my air filter. Before the change the gauge on the dash would range between 24.8 to 25.7 depending on how much around town driving I did on the weekend. Now it is 23.3 to 23.6. I undid everything to check the direction of the filter to make sure I had it in the correct direction. I think it is correct based on the how to thread on the forum. With the top of the housing down I have the gasket down with the paper portion of the filter up (if that makes sense) I checked to make sure the MAF sensor was plugged in all the way. Any suggestiions?
Old Aug 30, 2015 | 10:16 AM
Any codes? If not disconnect the negative battery cable for 30 minutes, the MAF sensor may need a reboot
Old Aug 30, 2015 | 03:04 PM
The filter will only go in the "right" way.
Reconnected the rubber hoses tightly? Including the breather hose and the Cool Air Intake hose.
Check to be sure you didn't disturb the coils and their wires, likewise the injectors.
Maybe your plugs decided they need attention now?
Old Aug 30, 2015 | 07:22 PM
No Codes. I will try to find one evening to disconnect battery
Old Aug 30, 2015 | 07:23 PM
I checked all the hoses but will recheck. I have a 2011 with only 50K miles on it. I thought plugs would want attention at 100K.
Old Aug 30, 2015 | 08:59 PM
RatRodS's Avatar
I would check the mileage with the trip odometer and take the miles driven and divide by gallons pumped. I would use the same pump, gas station and I prefer to fillip in the morning. See if it is the same as the gauge.
Old Aug 31, 2015 | 10:26 AM
x2 - and to get any worthwhile mileage calculations you really need to calculate the mileage over several tank loads - a single tankload, or the instantaneous readouts are not going to be very accurate at all. There are just too many variables involved for a quick and dirty calculation.
Old Aug 31, 2015 | 01:16 PM
Silverfox's Avatar
Not sure if this is a possible but did you use an OEM AC Filter ??? or??
Old Aug 31, 2015 | 02:15 PM
An over oiled K&N filter will drop your mpg!
AC66Bronco
May 16, 2013 11:33 AM
TXhhr83
Fuel Economy - Hypermiling
17
Jan 25, 2011 07:16 PM
