Good suggestion led to filler neck replacement
Old Jul 29, 2024 | 12:56 PM
  #31
fastsuv's Avatar
Unfortunately, that size is out of stock at Filler Neck Supply.
I'll have to look online for another source.
Rock Auto only has the plastic Dorman one.
Steve
Old Jul 29, 2024 | 01:40 PM
  #32
Fill out the order sheet online they’ll get one out to you
click on add to wish list
Old Jul 29, 2024 | 01:48 PM
  #33
fastsuv's Avatar
Which direction for the overflow nipple did you get (Parallel, Diagonal, Perpendicular)?
Steve
Old Jul 29, 2024 | 01:56 PM
  #34
I got the straight one.
Old Jul 29, 2024 | 02:14 PM
  #35
fastsuv's Avatar
I can't add it to the cart because it shows out of stock.
When you said to fill out the order sheet online did you mean there is another way to order?
Steve
Old Jul 29, 2024 | 02:53 PM
  #36
I clicked on add to cart and an order sheet came up. Perhaps contact them.
most of the ones on Amazon and EBay have reviews reporting bad welds
Old Jul 30, 2024 | 07:23 AM
  #37
fastsuv's Avatar
I called them, but they had a recording saying that they can't answer calls due to staffing issues and to Email instead.
I sent an Email yesterday, so I'm waiting for a response.
Steve
Old Jul 30, 2024 | 08:26 AM
  #38
Fastsuv
Are you going to order more than 1 ? Figured you would stock up for your herd of HHRs.
Old Jul 30, 2024 | 09:50 AM
  #39
fastsuv's Avatar
Fastsuv
Yes, I was going to order a couple while they are still available.
Steve
Old Jul 30, 2024 | 10:18 AM
  #40
If I had to do it again, I would order diagonal or 90 degree. So you could position the hose clamp on the recovery line in a way that does not try to slice your finger open whenever you need to turn the cap.
