headlight bulb alignment
Old Jan 21, 2019 | 06:05 AM
Cliffs51's Avatar
I cant get the bulb to turn enough to make the filament vertical as it should be. These are depo headlights.
Old Jan 21, 2019 | 06:08 AM
Cliffs51's Avatar
Filament is canted off to one side
​​​​​​​I cant get the bulb to turn enough to make the filament vertical as it should be. These are depo headlights.
Old Jan 21, 2019 | 06:45 AM
Are you sure the o ring gasket from the old bulb isn't stuck to the housing?
Old Jan 21, 2019 | 06:48 AM
Did you recently replace the bulbs ? If so, are you sure that the old sealing gasket came out with the old bulb ? The old gaskets will stick to the headlight housing then you'll have trouble because the new bulbs have their own gaskets. 2 gaskets make it almost impossible to insert the new bulbs.
Old Jan 21, 2019 | 07:32 AM
Cliffs51's Avatar
Ill check that today. Thanks
Old Jan 23, 2019 | 06:36 AM
And............................................... ...............?
Old Jan 23, 2019 | 07:08 AM
solman98's Avatar
Maybe it was a "doh" moment.
Old Jan 23, 2019 | 07:17 AM
Cliffs51's Avatar
Rubber gasket had nothing to do with it. I bought some new top of the line sylvania halogens and put them in. Now the lights work good with plenty of high beam illumination. They are canted to one side instead of vertical though so I guess that makes no difference.
Old Jan 23, 2019 | 07:25 AM
solman98's Avatar
If they are not vertical, they are not in properly.
Old Jan 23, 2019 | 08:04 AM
Cliffs51's Avatar
It could be the depo headlight housings are made wrong. They are seated correctly and working great. Thats all that matters to me
